Module Web Services API SOAP (developer)
Revision as of 12:51, 12 August 2019 by Eldy (talk | contribs)
Web services
Numero/ID of module 2600
User doc. of module Not applicable
Function
When enabling this module, you enable usage of web services provided by Dolibarr server. You can then make SOAP call of different web services provided by Dolibarr.
Warning.png SOAP is a deprecated protocol. It is highly recommended to use the Module Web Services REST instead.
Dolibarr web services server
Once module webservices is activated, Dolibarr become also a server of web services. So you can send your own SOAP request to relative URL /webservices/server_xxx.php where xxx can be
  • "actioncomm"
  • "category"
  • "contact"
  • "invoice"
  • "order"
  • "other"
  • "productorservice"
  • "supplier_invoice"
  • "thirdparty"
  • "user"
For example on Dolibarr demo, send your SOAP requests to https://demo.dolibarr.org/webservices/server_other.php
Only few services are available. You can see full list of Dolibarr Webservices provided, by calling the URL with no POST parameters.
For example, to see all Webservices functions available on Dolibarr demo, just call the following URL with no parameters:
To get the WSDL file that describe webservices contracts, you can call:
https://demo.dolibarr.org/webservices/server_other.php?wsdl
Dolibarr web services client
Note that you can see an example of code for a PHP client calling this relative URL /webservices/server_other.php
For example on Dolibarr demo, call the client user interface
https://demo.dolibarr.org/webservices/demo_wsclient_other.php
List of provided services
List of available services can be viewed by calling the page /webservices/ on your Dolibarr installation. For example, for the demo Dolibarr server, full URL is: https://demo.dolibarr.org/webservices/
This list is very short but will be completed with future Dolibarr versions...
