Module Pibarcode
Revision as of 23:18, 11 August 2019 by Eldy (talk | contribs)
Module name PiBarcode
Last update date / Date mise à jour fiche / Fecha última actualización 2019-08-11
Add a new barcode generation engine. This engine use the PHP library Pibarocde (non free).
Go on Module Barcode setup page and choose "Pibarcode" as the engine to build barcode.
To complete
