Module TwoFactorAuth
Module name TwoFactorAuth
Editor / Editeur Régis Houssin (iNodbox) - https://www.inodbox.com/
Last update date / Date mise à jour fiche / Fecha última actualización 2019-08-11
With this module, You can add a Double Factor Authentication (2FA) in Dolibarr. This modules support the protocol OTP. It does not support U2F.
The module is compatible with 2FA OTP tools like Google Authenticator, Authy, ...
