User:Jtraulle/DiscourseMigration
This page gathers info about Discourse migration.
Tentative design
600x600px
Custom CSS to add
Go to Admin → Customize → Themes → Light → Edit CSS/HTML → Common → CSS and paste :
#header {
background-color: rgb(61,95,147);
background-image: url(https://www.dolibarr.fr/templates/dolibarr/images/shadows/light/header-overlay.png),url(https://www.dolibarr.fr/templates/dolibarr/images/overlays/headers/header-6_dolibarr.png);
background-repeat:repeat-x, no-repeat;
background-position-x: 600px;
#inner-header {
max-width: 1110px;
height: 105px;
margin: auto;
#headermodule {
float: right;
margin: 10px 0;
.banneritem {
margin-right: 8px;
#main {
background: url(https://www.dolibarr.fr/templates/dolibarr/images/header-overlay.png) 50% -90px repeat-x !important;
background-color: rgba(0, 0, 0, 0);
background-color: #FFFFFF !important;
.d-header {
background-color: inherit;
box-shadow: inherit;
.d-header .wrap .contents, #main-outlet {
background-color: #FFFFFF;
#logo {
float: left;
margin: 5px 0;
display: block;
max-width: 100%;
margin-left: 4px;
margin-top: 32px;
/* menu */
#nav {
background-color: rgb(56,90,127) !important;
background: linear-gradient(rgba(56,90,127,.5), rgba(56,90,127,1)),url(https://www.dolibarr.fr/templates/dolibarr/images/shadows/light/nav-overlay2.png) 50% 0 repeat-x !important;
#nav ul {
padding:0;
margin:0;
#nav ul li {
display: inline-block;
margin: 0 0 0 0;
padding: 8px 4px 4px 12px;
#nav #decalmenu {
max-width: 1126px;
margin: auto;
padding: 0;
#nav ul li a {
color: #FFF;
font-weight: bold;
text-decoration: none;
font-size: 13px;
padding: 6px 5px 4px 5px;
height: 26px;
.backshadow {background: url(https://www.dolibarr.fr/templates/dolibarr/images/shadows/light/nav-overlay3.png) 0% 0 repeat-x;}
#nav arrowafterul { background: url(https://www.dolibarr.fr/templates/dolibarr/images/shadows/light/menus/menutab-r.png) 0 0 no-repeat; }
#nav ul li { background: url(https://www.dolibarr.fr/templates/dolibarr/images/shadows/light/menus/menutab-r.png) 0 0 no-repeat; min-height: 36px; }
#nav ul li.active, #nav ul li.active { opacity: 0.8; }
#nav ul li:hover, #nav ul li:hover .item, #nav ul li.active:hover {
background-image: -webkit-gradient( linear, left top, left bottom, color-stop(0, rgba(255,255,255,.3)), color-stop(1, rgba(0,0,0,.3)) );
#mainmenu {
#rokajaxsearch, form#mod-finder-searchform {
margin-right: 10px;
margin-left: 68px;
margin-bottom: 10px;
.roksearch_search_str {
width: 150px;
input.search-query {
padding-right: 14px;
padding-right: 4px \9;
padding-left: 14px;
padding-left: 4px \9;
margin-bottom: 0;
-webkit-border-radius: 15px;
-moz-border-radius: 15px;
.finder .search-query {
width: 132px;
.form-search .input-append .search-query,
.form-search .input-prepend .search-query {
-webkit-border-radius: 0;
-moz-border-radius: 0;
border-radius: 0;
.form-search .input-append .search-query {
-webkit-border-radius: 14px 0 0 14px;
-moz-border-radius: 14px 0 0 14px;
.form-search .input-append .btn {
-webkit-border-radius: 0 14px 14px 0;
-moz-border-radius: 0 14px 14px 0;
.form-search .input-prepend .btn {
.form-search input,
.form-search textarea,
.form-search select,
.form-search .help-inline,
.form-search .uneditable-input,
.form-search .input-prepend,
.form-search .input-append,
.form-inline input,
.form-inline textarea,
.form-inline select,
.form-inline .help-inline,
.form-inline .uneditable-input,
.form-inline .input-prepend,
.form-inline .input-append,
.form-horizontal input,
.form-horizontal textarea,
.form-horizontal select,
.form-horizontal .help-inline,
.form-horizontal .uneditable-input,
.form-horizontal .input-prepend,
.form-horizontal .input-append {
*display: inline;
*zoom: 1;
margin-bottom: 0;
vertical-align: middle;
.form-search .hide,
.form-inline .hide,
.form-horizontal .hide {
display: none;
.form-search label,
.form-inline label,
.form-search .btn-group,
.form-inline .btn-group {
.form-inline .input-prepend {
margin-bottom: 0;
.form-search .radio,
.form-search .checkbox,
.form-inline .radio,
.form-inline .checkbox {
padding-left: 0;
margin-bottom: 0;
.form-search .radio input[type="radio"],
.form-search .checkbox input[type="checkbox"],
.form-inline .radio input[type="radio"],
.form-inline .checkbox input[type="checkbox"] {
float: left;
margin-right: 3px;
margin-left: 0;
#footer {
margin: auto;
background: #e3e3e3;
border-top: 1px solid #ccc;
padding: 5px;
color: #888;
text-align: center;
Allow PostgreSQL to be accessed from an external application
Useful to be able to access the database from a graphical client (like pgAdmin 4, TablePlus or Postico for example).
1. Expose the 5432 TCP port from the container to the host by adding this line to the expose:
section of containers/app.yml
- "5432:5432"
2. Rebuild the container to take into account modifications to app.yml
./launcher rebuild app
3. Enter into the container, login as the default postgresql user, add a new user and grant it all perms to the database
./launcher enter app sudo -u postgres psql discourse CREATE USER my_username WITH PASSWORD 'my_password'; GRANT ALL PRIVILEGES ON DATABASE "discourse" to my_username; GRANT ALL PRIVILEGES ON ALL TABLES IN SCHEMA public TO my_username; \q
