Module Stripe
Stripe | |
Numéro/ID du module | 50300 |
Doc développeur du module |
This module allows
- to display the list of the Stripe mode of payment in Stripe in Dolibarr
- to pay, using Strong Customer Authentication (SCA), for orders, invoices, lines of contracts, subscriptions or any free amount, online, using Stripe (https://www.stripe.com).
Once the mandatory identifiers are entered, you benefit from URL links, provided by Dolibarr, to make online payments. These links are provided as "generic link" on the Stripe configuration page. But you will find them also as "dedicated link" on the page of each invoice, each order, each contract, or each member for the payment of memberships.
Variants
Stripe offers several modes of operation. The old default mode is the use of Stripe's "charge" APIs. As of September 2019, these APIs are deprecated to implement the SCA on online payments and SecureID v2 (https://stripe.com/docs/strong-customer-authentication). The v10 is ready for this change. Dolibarr v10 offers 2 other modes of operation:
- By going to home - configuration - various and adding the constant STRIPE_USE_INTENT_WITH_AUTOMATIC_CONFIRMATION to 1, Dolibarr will use the PaymentIntent Stripe APIs according to the workflow "Automatic Confirmation" (https://stripe.com/docs/payments/payment-intents/quickstart) , which is ready for the SCA.
- By going into home - configuration - miscellaneous and adding the STRIPE_USE_NEW_CHECKOUT constant to 1, Dolibarr will use the CheckOut Stripe APIs according to the "Server Integration" workflow (https://stripe.com/docs/payments/checkout), which is also ready for the SCA.
At maturity, one of these two variants, already operational in v10, will become the default mode.
