Module CustomizeForms
Revision as of 11:59, 28 July 2019 by Paulorcdo (talk | contribs)
Module name CustomizeForms
Editor / Editeur paulorcdo - https://www.trucolivre.com.br/dolibarr/
Download or buy page / Page achat ou téléchargement External module - On [1]
Last update date / Date mise à jour fiche / Fecha última actualización 2019-07-28
Note / Nota Module CustomizeForms
Logo
Customize Forms allows you to create new features in 24 dolibarr forms ( + 430 standard fields and + all extra fields)
1- Hide fields;
2- Make fields as mandatory (Javascript);
3- Disable fields;
4- Create Custom Header and Footer;
5- Define default values for fields (texts, lists, html, selection and categories);
6- Create tooltip with instructions on the fields;
7- Create auxiliary lists of preformatted texts and phrases to easily insert into the fields (text, html);
8- Change the presented names of the fields without changing the translations;
2- The module is installed in the Tools menu of Dolibarr, click on the menu and on the left will appear the link Customize Forms.
3- Click on the Customize Forms link and you will be taken to the system home page.
Screens
Screen 1
Home Page - List Forms:
HomePage
  • The Home Page lists all 24 Dolibarr forms that can be configured by Customizeforms.
  • The Qty column tells you how many fields can be set on each form.
  • To Customize a Form, just click the pencil on the right form.
Screen 2
Page Edit Form - List All Form Fields:
Form
  • In this example, we click on the Home Page in the New Commercial Proposal - Customer form.
  • This page only displays fields with default values that have already been set. All fields of the form are displayed on this page.
1 - Extrafields that were created for this module will be inserted automatically when you open the page.
2 - The Header and footer fields are options that can be added to the form.
  • Name: Field Name
  • Situation: Current field status - Can be Visible, Invisible, Disabled, or Required.
  • Default Value: Value set to appear as default for the field (text fields, checkbox, selects, textarea).
  • Tag: New Name Defined for Field
  • Auxiliary List: List of Text separated by line breaks that can be added in any text field or textarea.
  • Help Text: Help text that appears when you approach the mouse.
Screen 3
Page Edit Field:
CustomizeForms
In this example, we click in the New Commercial Proposal - Customer form on the Customer field.
  • To Hide fields:
    • Click in the combo box Define Visibility and Mandatory and select Invisible option
  • To Make fields as mandatory (Javascript);
    • Click in the combo box Define Visibility and Mandatory and select Required option
  • To Disable field;
    • Click in the combo box Define Visibility and Mandatory and select Disable option
  • To Define default values for field (texts, lists, html, selection and categories);
    • Click in the combo box Set Default Value and select the desired option (Dolibarr options to combo box and checkbox, other field type only digit text to default value)
  • To Change the presented name of the field without changing the translations;
    • Digit new name text to Modify Field Name
  • To Create auxiliary lists of preformatted texts and phrases to easily insert into the fields (text, html);
    • Digit List of Text separated by line breaks that can be added in any text field or textarea in Create Auxiliary List to insert into text or HTML fields
  • To Create tooltip with instructions on the fields;
    • Digit html text to Create Tooltip with Help Info
___
To create Headers and Footers on a form:
1- Choose the form on the home page of the module;
2- In the chosen form, click in the Header or Footer field;
  • Click in the combo box Define Visibility and Mandatory and select Visible option;
  • Digit new name text to Modify Field Name, this field is a name of Header/Footer in the left;
  • Digit html text in the field Set Default Value , this field is a content of Header/Footer in the right;
Prerequisites
Partial Features - Dolibarr ≥ 5.0.3
All Features - Dolibarr ≥ 9.0.3
Demo
View DEMO:https://www.trucolivre.com.br/dolibarr/ user:demo passw:demo
Video
View Video: https://www.youtube.com/watch?v=wTR9DMnpIck
