Roadmap and Release 2.7.0 ("Exploitation and security" version)
Revision as of 17:28, 25 July 2019 by Eldy (talk | contribs)
Version: 2.7.0 (List of other versions on page Category:RoadMap)
Release date: 2009-12-04
  • Exploitation and security (include a help center, better tools to install/exploit, more security features,...)
  • Some other not planned features, depending on external contributions.
Detailed Changelog:
For users:
- New: Add a print icon to show a page to print without menus.
- New: Can add a free text on bank cheque receipts.
- New: Price level can be defined also for prospects.
- New: Add a help and support center.
- New: Can export commercial proposals.
- New: Can use a cache for xcal exports.
- New: Option for faster confirmation process with one ajax popup.
- New: Complete theme bluelagoon and rodolphe
- New: Can select third parties emails in emailing module for all third parties with expired contract's lines.
- New: Can add a field errors-to in emailing.
- New: Can use inline images in emails.
- New: Add predefined invoices (can be use for repeated invoices).
- New: Add a confirmation when cloning products.
- New: Add stock in product lists.
- New: Can filter list of stock movement on date or product.
- New: Added a link from product list to their stock movements.
- New: Several speed enhancements after using the Google Page speed plugin for FireBug.
- New: Add a confirmation on dangerous admin purge feature.
- New: Add navigation on donation sheets.
- New: Added estimated value for stocks.
- New: Added module Gravatar to found photo of users or members from their email on gravatar.com.
- New: Include Dolibarr version in suggested dump filename.
- New: Enhancement in project module.
- New: Add log tab on emailing module.
- New: Minor enhancements in look themes.
- New: Add option to hide help in menu.
- New: Added a "force LDAP synchronize" on member and contact cards.
- New: Can split a discount into two smaller discount. This allows to use a discount on an invoice even if invoice amount is lower than discount credit available.
- New: Can use variables into the free text on PDF (__TOTAL_TTC_, __TOTAL_VAT...)
- New: Increase page loading speed (all changes reported by Google PageSpeed tool has been added).
- New: Add support of constant MAIN_ONLY_LOGIN_ALLOWED to allow to lock all access to any users except the one defined in constant.
- New: Add an admin page of PHP sessions with a way to lock new connections for other users than yourself. Can also purge existing sessions.
- New: Add point of sale module.
- New: Better usage when using with smartphones.
- New: Add module FTP client.
- New: Can set first day of week.
- New: Installer now create a .htaccess to protect documents directory.
- New: Experimental support for Postgresql.
- New: Full support of SMTPS (can works with Google SMTP).
- Fix: "Now" link works when date popup is not used.
- Fix: Debug seriously the email notification module.
- Fix: Error Call to a member function trans when refusing a supplier order.
- Fix: Fix payment conditions on commercial proposals.
- Fix: Nb of orders to process was wrong.
- Fix: Customer code was not correct on PDF it if contains special characters.
- Fix: Can update price even with "NPR" VAT rates.
- Fix: When product type is missing, description is not lost when adding new product lines.
- Fix: CC and BCC in emails was not used if using SMTPS handler.
- Fix: Last character was lost when text end with n or r.
- Fix: LDAP synchronization is now more robust (transaction and use modify instead of delete/add).
- Fix: Fix: Setup of member synchronization does not conflict with contact or user synchronization.
For translators:
- Update some language files.
- Can accept right to left languages. Added an "automatic" arabe translation.
For developers:
- An external module can force the third party code to be required whatever is the rule of third party code module.
- Update fckeditor to 2.6.4.
- Update Smarty to 2.6.26.
- Removed some deprecated code and files.
- Creation of directory in module descriptor is simpler.
- Can use an alternate document_root directory to develop with sources on two repositories.
- Removed useless code of old commercial module.
- Move some modules into the CVS modules repository dolibarrmod. This reduces amount of code in main branch.
- Updated wiki documentation.
- Better W3C standard.
- Can add init data when enabling a module.
- Can fix some corruptions in database by calling the update page /install/repair.ksh
- Log files contains more information (PHP_SELD added and OS user used for log of command lines scripts)
- Can protect a module to not being enabled if javascript disabled.
- If module numberwords is installed, code can use langs->getLabelFromNumber  to get value of an amount in text.
- A module can add subsitution keys in makesubsitutions() functions.
- Add $conf->browser->phone defined to optimise code for smartphone browsers.
- All external libs are now in same directory /includes.
- All install files are now in same directory /install.
