Roadmap and Release 4.0.0
Revision as of 17:25, 25 July 2019 by Eldy (talk | contribs)
Version: 4.0 (List of other versions on page Category:RoadMap)
Release date: June 2016
Will contain a list of enhancement and big fixes defined into issue/task traker available at https://github.com/Dolibarr/dolibarr/issues. See raw ChangeLog lower for details.
  • Enhancement of look. Better responsive design
  • Choose of fields to show on list is now also available for proposal, invoices, orders
  • Module cron is now complete. Any external module can add their own scheduled task with a simple declaration.
  • Full management of recuring/templates invoices. Used with contract module, you can follow subscriptions.
  • New module Supplier proposals.
  • New module Loan.
  • Overwriting translation is now possible from GUI.
  • A ton of minor enhancements
Detailed Changelog:
For users:
NEW: Add reccuring invoice feature and automatic generation of invoices.
NEW: Add module "Loan" as stable.
NEW: Add module "Supplier commercial proposal" (price request) is set to stable status.
NEW: Experimental module Accountancy Expert
NEW: Experimental module Multicurency
NEW: Show into badge on tab head the number of dedicated contacts for all objects.
NEW: Add a checkbox to select/unselect all lines on page that support mass actions (like invoice list page)
NEW: Add a new method for margin calculation. Added margin on "cost price" to margin on WAP price and margin on "best supplier price".
NEW: Add an explanation message on shipment page to explain you can't make shipment if order is not validated
NEW: Add date_rum into table of thirdparty bank account.
NEW: The probability of lead/opportunity can be defined per lead.
NEW: Added Malta VAT into migration script
NEW: #4972 Translated Charges sociales (type 0) and Charges sociales (type 1) in reports page
NEW: Add Expense report into accountancy report
NEW: Add Expense report to approve into workboard
NEW: Selection of boxes is move on top of home page
NEW: Add filter on a keyword, status and nature into list of modules
NEW: Add hidden option BANK_DISABLE_CHECK_DEPOSIT to disable check deposit feature.
NEW: Add option MAIN_PUBLIC_NOTE_IN_ADDRESS
NEW: add html id/class to locate value in the DOM html
NEW: Add index on invoice status
NEW: Add constant MAIN_LOGTOHTML to 0 into other setup by default to save time when we need to make debug on hosted instance.
NEW: Add list of billed
NEW: Add minimum stock and desired stock into import/export profiles.
NEW: Add state into thirdparty export fields
NEW: Add more trackable events (create, submit and receive supplier order).
NEW: Add option MAIN_PROPAGATE_CONTACTS_FROM_ORIGIN
NEW: Add picto on module list to show warning and if module is an external module.
NEW: add product type filter on turnover report
NEW: Add state into list of fields available for personalized fields of thirdparties
NEW: Add statistics for interventions module
NEW: Add statistics on number of projets on home page
NEW: Add stats and late records into dashboard for supplier proposals.
NEW: Add the admin info on combo of type of contact
NEW: Add the event BILL_PAYED to list of supported events for module notification.
NEW: Add total weight and volume on PDF
NEW: Add hidden option to hide column qty ordered on shipments.
NEW: Add view of virtual stock into product list (when appropriate)
NEW: Add warning on tasks when they are late (add also the warning tolerance parameter)
NEW: Add weight/volume for one product into shipment export
NEW: Add width and height on product card
NEW: allow a document to be linked to project from another customer on config
NEW: allow project to be shared across entities (for multicompany module)
NEW: All variant of ckeditor config can be tested into the setup page of module.
NEW: Can change dynamically number of records visible into lists.
NEW: Can change type of extrafields for some combinations.
NEW: Can define number of first and last line into import wizard.
NEW: Can edit next execution date of a cron job.
NEW: Can edit value date of a vat payment after recording it.
NEW: Can filter modules on publisher
NEW: Can filter on employee status when building emailing from users
NEW: Can reopen an closed shipment
NEW: Can search on shipments into the quick search box
NEW: Can select dynamicaly number of lines to show on page on product, shipment, contact, orders, thirdparties
NEW: Can select fields to show on supplier orders list.
NEW: Can select fields to show on list also for list of customer orders, shipments and invoices.
NEW: Can select fields to show on proposal lists.
NEW: Can select language from combo list on page to overwrite a translation
NEW: Can select number of lines on page list for projects and tasks.
NEW: Can use ^ and $ (to say start with or end with like regex syntax) into search fields when search field is text. Bonus: ^$ can filter all lines with field not defined.
NEW: Clean and enhance code for cron engine
NEW: Can decrease stock on shipment closing/classifying (only if module lot is not enabled for the moment)
NEW: Disabled users are striked.
NEW: Enhance navigation of project module
NEW: fichinter lines ordered by rang AND DATE
NEW: hidden conf to use input file multiple from mail form
NEW: hidden feature: SUPPLIERORDER_WITH_NOPRICEDEFINED allow supplier order even if no supplier price defined
NEW: Hidden option MAIN_LANDING_PAGE to choose the first page to show after login works as a "global" option (llx_const) and as a "per user" option (llx_user_param).
NEW: Holiday is a now a RH module. All RH module provides by default visilibity on users of its hierarchy.
NEW: If error is reported during migration process, you can ignore it to avoid to be locked.
NEW: if nb total of lines provided in print barre_liste, display in title
NEW: If option to see non stable modules is on, add a filter into module list to filter on level (deprecated, experimental, development)
NEW: Include number of linked files into badge counter of "Linked files" tab.
NEW: Include sales representative into export of thirdparties
NEW: Indicator on workboard are red/green if late or not.
NEW: Into GED module, filename is truncated only if there is not enough space into table
NEW: Introduce a predefined job to run database backup
NEW: Introduce option MAIN_WEIGHT_DEFAULT_UNIT and MAIN_VOLUME_DEFAULT_UNIT to force output unit for weight and volume.
NEW: Introduce position of records into dictionnary of type of contacts
NEW: Link on user in leave context reach to leave tab.
NEW: List of user in agenda view per user show photo thumb
NEW: Margins module - Check/update buying price on invoice lines
NEW: Merge all admin tools (system and module admin tools) into same entry "Admin tools", so now things are clear: All features restricted to an admin user is inside "setup" (for setup) or "admin tools" (for action tools) instead of 3 different entries.
NEW: Merge all boxes "related objects" into one. This save a lot of room on most card and avoid often horizontal scoll.
NEW: Moved code that deals with bank categories to BankCateg. Created BankCateg::fetchAll function
NEW: Move Expense report menu from module to menu files
NEW: Move HRM dictionary from module to core dictionaries
NEW: Mutualize code to manage email substitution variables. Show available variables into page to edit email templates.
NEW: Mutualize code: Use one call of function "addThumbs", when possible, to generate thumbs files instead of several call of "vignette" function.
NEW: On translation admin page, admin can overwrite a translation value.
NEW: Option MAIN_LIST_FILTER_ON_DAY is supported on proposal list
NEW: Add reputation field for price supplier
NEW: Rest API token is no more reset at each call. We can reset it with param reset=1 on login call.
NEW: Selection of fields is available on member list.
NEW: Show a badge with number of withdraw requests done on the withdraw tab of invoice.
NEW: Add option to show detail per warehouse into reassort
NEW: Show total number of modules into the module list
NEW: Survey system has now a status like other objects. You can close or reopen a survey.
NEW: The note on time spent can be entered when using the view per day.
NEW: Use ellipsis truncation on too large left menu text
NEW: When a new field to show into lists is selected, the form is automatically submited and field added.
NEW: When creating a template invoice from a draft invoice, if there is link to contract on draft invoice, link is kept on template invoice.
NEW: When emailing is not sent completely, show progression.
For developers:
NEW: Add a css class style called 'reposition', so when clicking on a link with this class will move scrollbarr to be placed at same page location.
NEW: TimeZone can be supplied to mktime
NEW: hook in shipment card
NEW: Deprecated Societe::set_prospect_level, Societe::set_commnucation_level, Societe::set_OutstandingBill functions
NEW: A module can add, into its import profiles, a sql request to execute at end of import. This allow to update dernormalized data after import.
NEW: Add hook pdf_build_address
NEW: Add a parameter on graph function to show a generic graph when no data are available.
NEW: Add $object in parameter of pdf_build_address so we could include hook into the function.
NEW: Add a tool for developers to purge database with no loose of setup
NEW: Can disable a module by renaming dir of module into module.disabled (this save time for maintenance when working with FTP).
NEW: Created AccountLine::insert function and started using it for transaction creation
NEW: Created Account::__toString, Account::getFieldsToShow and Account::getAccountNumberOrder to refactor the way account number was shown
NEW: Created FormBank::getIBANLabel function to get the label of "IBAN" depending on bank account country
NEW: prepare for additional warehouse statuses
NEW: project sharing in select_projetcs_list function
NEW: Removed deprecated CommonObject::client property. Please use CommonObject::thirdparty instead
NEW: Removed unused FormOrder::selectSourcesCommande function
NEW: Renamed ActionComm::add function to ActionComm::create
NEW: Rename Form::select_date to Form::selectDate and Form::form_date to Form::formDate
NEW: Rename path for generiN
NEW: More phpunit tests. Include some REST API into automatic tests.
WARNING:
Dolibarr 4.0 should be compatible with PHP 7 but more feedbacks are still expected to confirm that.
Following changes may create regression for some external modules, but were necessary to make
Dolibarr better:
- Function log() of class CommandeFournisseur has been removed. Using it is no more required.
- Class Resource was renamed into DolResource to avoid conflict with a reserved PHP word.
- Method commonobject->add_thumb() has been renamed into commonobject->addThumbs().
- Method select_type_comptes_financiers() has been renamed into selectTypeOfBankAccount()
- Property ->client that was deprecated 6 years ago, is replaced in all core code with ->thirdparty.
- File '/core/tpl/document_actions_pre_headers.tpl.php' were renamed into '/core/actions_linkedfiles.inc.php'. So if you included it into your module, change your code like this to be compatible with all version:
  $res=@include_once DOL_DOCUMENT_ROOT . '/core/actions_linkedfiles.inc.php';
  if (! $res) include_once DOL_DOCUMENT_ROOT . '/core/tpl/document_actions_pre_headers.tpl.php';
