Security information
Securite.png Alerts
Last update: 2019-07-24
Some SQL injections vulnerabilities have been reported. They are a small risk as they are in page that need to be logged to be used. Fix is available into 9.0.6.
Art.png Features
Dolibarr implements several security features. Among them :
Encryption
  • User passwords can be encrypted in database [*7] [*8].
  • Database technical password can be obfuscated into the Dolibarr configuration file (conf.php) [*8].
  • Possibility to force HTTPS [*9].
//conf/conf.php file
//example of $dolibarr_main_force_https  configuration
$dolibarr_main_force_https = '1';//to force https
Values Description
0
No forced redirect
1
Force redirect to https, until SCRIPT_URI start with https into response
2
Force redirect to https, until SERVER["HTTPS"] is 'on' into response
Hacks and cracks
  • Works with register_globals on or off (off highly recommended) [*2].
  • Works with PHP safe_mode on or off (on recommended) [*3].
  • Production option to disable any technical information leakage like debug, error stacktrace, version informations (See configuration file) [*6].
  • Protection against SQL injection [*2].
  • Protection against XSS injection (Cross Site Scripting) [*1]. Note that it is better to also protect your web server by disabled Apache option
AcceptPathInfo Off
  • Protection against CSRF (Cross Site Request Forgery) [*5].
Pages and files access
  • Pages and contents are protected by centralized entry code to check permissions (granted on groups or users for each functional module) [*4] [*10].
  • Files saved by Dolibarr are stored in a different root directory than web application (so they can't be downloaded without passing by the Dolibarr wrapper) [*3] [*10].
  • Dolibarr directories content can't be accessed even if Apache option Indexes has be forgotten to on (should not) [*3].
Login protection
  • Delay anti brute force cracking on login page [*7].
  • Option for graphical code (CAPTCHA) against robots on login page [*7].
  • No passwords in logs, even in technical logs [*7].
  • Internal logger to save permanently all Dolibarr events about user's administration and successful or failed logins.
Viruses
  • Possibility to run an external anti-virus on every uploaded files [*3].
(*X) This solution is part of protection used to solve vulnerabilities classified by the OWASP Top Ten at range number X.
