Script development
Revision as of 13:21, 23 July 2019 by PolyglotBot (talk | contribs) (Import interlang links (links to translated versions of this page in other languages) from Multi Language Manager table.)
Location
The Dolibarr command line scripts must be located in the scripts directory in Dolibarr root. The scripts are then divided into sub-directories according to their vocation. A number of scripts is provided as standard.
Develop a new script
The scripts are often made for a specific need, it is likely that you do not find the one you want. In this case, we'll explain how to develop your own script.
Step 1 - Create the skeleton of the script
The first step is to take the skeleton script available in dev/skeletons/skeleton_scripts.php and copy and renaming it in directory scripts/mydir/myscript.php
Once renaming is done, give it permissions to execute. On linux, this is the command:
cd scripts/mydir;
chmod a+rx myscript.php
Then, run it to see if you can run the script in a command line mode. For this, on Linux, type:
php-cli ./myscript.php
or
php ./myscript.php
You must get the following output:
Usage: myscript.php param1 param2 ...
Step 2 - Editing script code
Modify the contents of the script to perform operations that interest you. All the code that lies between the tags
// ---------- START OF YOUR CODE HERE
and
// ---------- END OY YOUR CODE
is provided as an example. You can delete it and put the code that you want. Note that in this section, you can use the variable $db that is the resource to access Dolibarr database and is already initialized. The $conf object that contains Dolibarr configuration is also available.
Examples
Some code examples (to create orders, products...) are available into directory /dev/examples/.
