Module Workflow
Revision as of 13:21, 23 July 2019 by PolyglotBot (talk | contribs) (Import interlang links (links to translated versions of this page in other languages) from Multi Language Manager table.)
Workflow | |
Numero/ID of module | 6000 |
User doc. of module | Cette page |
Developer doc. of module | Module Workflow (development) |
This module allows you to install some workflow links to have automatic object creation. for example, when closing a commercial proposal with status "signed", this module will can automatically an order.
Life cycle / Business rules
This module show only available workflows according to activated modules.
