Module Thelia EN
Revision as of 13:21, 23 July 2019 by PolyglotBot (talk | contribs) (Import interlang links (links to translated versions of this page in other languages) from Multi Language Manager table.)
Module name
Editor / Editeur Alternik - http://aternatik.org/articles-et-ressources/logiciels/article/une-passerelle-thelia-dolibarr-en
Dolibarr min version: 2.7.1    Dolibarr max version: {{{maxversion}}}
Allows Dolibarr to make synchronization with the ECommerce application Thelia.
Not yet available.
Development of this module is not included inside standard CVS repository of Dolibarr but into the complementary modules area. So source code is hosted into following CVS repository:
  • CVS Repository: :ext:savannahlogin@cvs.savannah.nongnu.org:/cvsroot/dolibarr
  • CVS Module: dolibarrmod
To have a view on changes done on this repository, see page http://www.nltechno.com/stats/dolibarr/cvschangelogbuilder_dolibarrmod.html
