Module Rewards
Revision as of 13:21, 23 July 2019 by PolyglotBot (talk | contribs) (Import interlang links (links to translated versions of this page in other languages) from Multi Language Manager table.)
Module name Rewards
Editor / Editeur 2byte.es - http://www.2byte.es
Download or buy page / Page achat ou téléchargement External module - DoliStore
Reward your customers with a simple program points, where for every purchase they make, your customers will receive a number of points, which at any time will be able to redeem their purchases.
More info(Spanish only)
Module info by official developer: www.2byte.es
Technical info and manuals: www.2byte.es
Acquire the module: www.dolistore.com
Terms of Use, Maintenance and Support: www.2byte.es
