Module Reports
Revision as of 13:21, 23 July 2019 by PolyglotBot (talk | contribs) (Import interlang links (links to translated versions of this page in other languages) from Multi Language Manager table.)
Module name
Editor / Editeur 2byte.es (www.2byte.es)
Dolibarr min version: 3.1    Dolibarr max version: {{{maxversion}}}
Management, printing, viewing and exporting reports. The export can be done in CSV and PDF. You can request for further reports. The module allows us to manage groups of reports
More info(Spanish only)
Module info by official developer: www.2byte.es
Technical info and manuals: www.2byte.es
Acquire the module: www.dolistore.com
Terms of Use, Maintenance and Support: www.2byte.es
