Module Pibarcode
Revision as of 13:21, 23 July 2019 by PolyglotBot (talk | contribs) (Import interlang links (links to translated versions of this page in other languages) from Multi Language Manager table.)
Module name PiBarcode
Add a new barcode generation engine. This engine use the PHP library Pibarocde (non free).
Go on Module Barcode setup page and choose "Pibarcode" as the engine to build barcode.
To complete
