Module PHPSysinfo
Revision as of 13:21, 23 July 2019 by PolyglotBot (talk | contribs) (Import interlang links (links to translated versions of this page in other languages) from Multi Language Manager table.)
Module name PHPSysInfo
Include into menu, an entry PHPSysinfo that show all system information of PHPSysinfo tool (See projet http://phpsysinfo.sf.net)
Click on menu entry "PHPSysinfo" found into menu System tools or Administration tools. System information will be shown on main page.
