Module OSCommerceWS (developer)
Revision as of 13:21, 23 July 2019 by PolyglotBot (talk | contribs) (Import interlang links (links to translated versions of this page in other languages) from Multi Language Manager table.)
OSCommerceWS
Numero/ID of module 900
User doc. of module Module OSCommerceWS
Este módulo es obsoleto y ya no está disponible. Las posibles razones son:
  • El módulo no se mantiene desde hace más de 1 año
  • El módulo no funciona en las versiones recientes de Dolibarr. Las modificaciones necesarias para que lo haga no se han aplicado todavía.
  • El módulo ofrecía unas funcionalidades que ahora se encuentran disponibles en la versión estándar de Dolibarr.
The OSCommerceWS module is used to synchronize informations between OSCommerce and Dolibarr using Web services.
By this way, it is possible to
  • publish into OSCommerce some products created into Dolibarr.
  • import orders (and details) from OSCommerce into Dolibarr.
  • import customers fomr OSCommerce into Dolibarr.
This module works using the NuSOAP library embedded into Dolibarr.
Code
All source code for this module is available inside directory htdocs/oscommerce_ws.
Source code you can find into directory htdocs/boutique is dedicated to Module OSCommerce (developer) that works differently.
The directory ws_server/ must be copied onto the OSCommerce server, inside directory catalog/. It must then be configured, by modifying the file ws_server/includes/configuration.php to define the OSCommerce configuration (how to access databases).
Permissions
None
Tables SQL
None
