Module Massorders
Revision as of 13:21, 23 July 2019 by PolyglotBot (talk | contribs) (Import interlang links (links to translated versions of this page in other languages) from Multi Language Manager table.)
Module name
Editor / Editeur 2byte.es - www.2byte.es
Prerequisites / Prérequis Dolibarr min version 3.3
With the module get remarkable efficiency in processing bulk orders. It is mainly suitable for companies that work with a large number of orders, and want to optimize the time spent to become bills.
More info(Spanish only)
Module info by official developer: www.2byte.es
Technical info and manuals: www.2byte.es
Acquire the module: www.dolistore.com
Terms of Use, Maintenance and Support: www.2byte.es
