Module Docs
Revision as of 13:21, 23 July 2019 by PolyglotBot (talk | contribs) (Import interlang links (links to translated versions of this page in other languages) from Multi Language Manager table.)
Module name
Editor / Editeur 2byte.es (www.2byte.es)
Dolibarr min version: 3.2    Dolibarr max version: {{{maxversion}}}
With this module you can manage digital documents (. Doc,. Xls,. Odt,. Jpg,.) Of your customers in an orderly manner, and above all in a safe, as the added functionality of document protection , will manage access permissions, in a comfortable and easy.
More info(Spanish only)
Module info by official developer: www.2byte.es
Technical info and manuals: www.2byte.es
Acquire the module: www.dolistore.com
Terms of Use, Maintenance and Support: www.2byte.es
