Module BitTorrent
Revision as of 13:20, 23 July 2019 by PolyglotBot (talk | contribs) (Import interlang links (links to translated versions of this page in other languages) from Multi Language Manager table.)
Module name bittorrent
Add into Dolibarr, the capability to be a Bit Torrent tracker. This means you are able to serve files to the world on the Bit Torrent network with no need of external web sites or tools.
To complete
