Module Belgium EN
Revision as of 13:20, 23 July 2019 by PolyglotBot (talk | contribs) (Import interlang links (links to translated versions of this page in other languages) from Multi Language Manager table.)
Module name Belgium
Editor / Editeur Laurent Léonard - http://www.open-minds.org
It allows you to generate and publish InterVAT documents.
Go into new menu entry "Belgium" to find all new features.
Development of this module is not included inside standard CVS repository of Dolibarr but into the private complementary modules area DoliForge. So source code is hosted into following source repository:
