Module 2WebMail EN
Revision as of 13:20, 23 July 2019 by PolyglotBot (talk | contribs) (Import interlang links (links to translated versions of this page in other languages) from Multi Language Manager table.)
Information
Module name | 2WebMail |
Editor / Editeur | 2byte.es - http://www.2byte.es |
Download or buy page / Page achat ou téléchargement | External module - Dolistore |
Prerequisites / Prérequis |
Last update date / Date mise à jour fiche / Fecha última actualización | 2019-07-23 |
Note / Nota |
Manage with Dolibarr the e-mails from company mail system
More info(Spanish only)
Module info by official developer: www.2byte.es
Technical info and manuals: www.2byte.es
Acquire the module: www.dolistore.com
Terms of Use, Maintenance and Support: www.2byte.es
