FAQ Directory Custom external modules
Revision as of 13:20, 23 July 2019 by PolyglotBot (talk | contribs) (Import interlang links (links to translated versions of this page in other languages) from Multi Language Manager table.)
For very old version of Dolibarr, you must execute this before being able to install an external module.
Why my module does not appear ?
  • Make sure Dolibarr is already installed and configured on your workstation or development server.
  • In your Dolibarr installation directory, edit the htdocs/conf/conf.php file
  • Find the following lines:
   php
   //$dolibarr_main_url_root_alt ...
   //$dolibarr_main_document_root_alt ...
  • Uncomment these lines (delete the leading //) and assign a sensible value according to your Dolibarr installation
For example :
   * UNIX:
       php
       $dolibarr_main_url_root = 'http://localhost/Dolibarr/htdocs';
       $dolibarr_main_document_root = '/var/www/Dolibarr/htdocs';
       $dolibarr_main_url_root_alt = '/custom';
       $dolibarr_main_document_root_alt = '/var/www/Dolibarr/htdocs/custom';
   * Windows:
       php
       $dolibarr_main_document_root = 'C:/My Web Sites/Dolibarr/htdocs';
       $dolibarr_main_document_root_alt = 'C:/My Web Sites/Dolibarr/htdocs/custom';
You may have to create the htdocs/custom directory first if it doesn't exist yet.
  • Unzip the custom module zip file in the htdocs/custom directory
  • You should now have a htdocs/custom/modulename directory
  • Refresh your browser, Go to "Setup" -> "Modules"
The module displays in one of the sections, you could enable it and then start using it ;)
If the module is under development or experimental
Got to "Setup" -> "Other setup" and set MAIN_FEATURES_LEVEL to 2
For more information about the conf.php file take a look at the conf.php.example file.
