Configuration file
Revision as of 13:20, 23 July 2019 by PolyglotBot (talk | contribs) (Import interlang links (links to translated versions of this page in other languages) from Multi Language Manager table.)
The Dolibarr configuration file is conf/conf.php. It is created by the automatic install process.
Content
Content of this file is :
$dolibarr_main_document_root="/home/www/dolibarr/htdocs";
$dolibarr_main_url_root="http://mydomain.com/dolibarr";
$dolibarr_main_db_type="mysql";
$dolibarr_main_db_host="localhost";
$dolibarr_main_db_port="3306";
$dolibarr_main_db_name="dolibarr";
$dolibarr_main_db_user="dolibarr";
$dolibarr_main_db_pass="";
Other options:
$dolibarr_main_demo="demologin,demopass"
-> Disable some features to limit software when used as a demo software. This is to avoid that everybody make everything with a demo instance of Dolibarr.
$dolibarr_main_prod="1"
-> When this option is added in conf file, no information will be reported by Dolibarr when an internal error occurs. This is to use in a production environment to hide any information to hackers.
$dolibarr_main_authentication="dolibarr"
-> Allows to change the way the password is checked when a user ty to login to Dolibarr:
  • Value "dolibarr" means check is done with the password stored in database.
  • "ldap" ask to use a LDAP server (in this case, you must also define other LDAP parameters (See file conf.php.example)
  • "http" use basic http protocol (need to configure your web server to set dolibarr inside a basic authentication area)
$dolibarr_main_force_https = "1";
-> Force url to https.
Dolibarr provide a model of file named conf/conf.php.example where each parameter is commented.
Read/Write file
This file must never be modified, never read directly by any Dolibarr feature.
It is created by the install or update process of Dolibarr (install/index.php) that is the only process allowed to make actions on this file.
Usage in coding
Content of file must be used by developers by using predefined loaded constants or the object $conf created by the code into files master.inc.php or main.inc.php (that must be included at beginning of every PHP program: master.inc.php for scripts or main.inc.php for pages). Your code must never open the config file and read it directly. This is not necessarly.
  • $dolibarr_main_data_root is known in code in constant: DOL_DATA_ROOT (that indicate physical path of directory with data files uploaded or created by Dolibarr).
  • $dolibarr_main_document_root is known in code in constant: DOL_DOCUMENT_ROOT (that indicate physical path of Dolibarr directory programs).
  • $dolibarr_main_url_root is known in code in constant: DOL_URL_ROOT (that indicate relative URL that is Dolibarr root).
  • $dolibarr_main_db_type is known in code on variable $conf->db->type
  • $dolibarr_main_db_host is known in code on variable $conf->db->host
  • $dolibarr_main_db_port is known in code on variable $conf->db->port
  • $dolibarr_main_db_name is known in code on variable $conf->db->name
  • $dolibarr_main_db_user is known in code on variable $conf->db->login
  • $dolibarr_main_db_pass is not known by code. It is read by script master.inc.php that created a connexion object $db then variable $dolibarr_main_db_pass is erased.
See tutorial on page Module development or Script development for more information.
