Roadmap and Release 3.3.0 ("gpl v3+" version)
Version: 3.3.0 (List of other versions on page Category:RoadMap)
Release date: January 2013
- Uniformizing of code
- War against major missing and not stable features
Detailed Changelog:
For users:
- New: Add holiday module, to declare and follow holidays of your employees. - New: Add margin management module. - New: Add new theme Amarok. - New: [ task #289 ] Can reorder tasks. - New: Add field "signature" into user card. If filled, text is added at end of predefined email texts. If option MAIN_MAIL_DO_NOT_USE_SIGN is on, this feature is disabled. - New: Can input a payment back onto an credit note. - New: Add link "Back to list" on all cards. - New: After first install, warning are visible onto mandatory setup not configured. Show also total number of activated modules. - New: Can filter list of proposal, order or invoice on sales representative. - New: Add supplier ref on supplier orders. - New: Can export supplier orders and customers shipments. - New: First change to install external plugins from gui (experimental). - New: Monaco is like France for default vat calculation - New: Can list elements (invoices, orders or proposals) on a particular user contact). This allow to view a "basket" of its elements. - New: Show bank account on payment list of invoice card. - New: Cloning project allow to clones task, notes, files, contacts. - New: Enhance default style. - New: Can edit and resiliate member status from list. - New: Can insert URL links into elements lines. Also reported into PDF. - New: When a member is validated, we can subscribe to mailing-lists according to its type. - New: Add a tab into members statistics to count members by nature. - New: Add link to third party into sells and purchase journal. - New: Suggest a method to generate a backup file for user with no access to mysqldump binary. - New: Can also use extrafields on contacts/addresses and users. - New: Support unique field for extrafields. - New: Extra fields supports more types (int, string, double, date, datetime). - New: Can correct stock of a warehouse from warehouse card. - New: [ task #185 ] Can input amount when correcting stock to recalculate PMP. - New: [ task #454 ] Add "No category" into filters on category. - New: Auto check box on page to edit interface options of user. - New: More surface control on stock correction page. - New: Add great britain provinces. - New: [ task #494 ] Send an email to foundation when a new member has auto-subscribed. - New: [ task #326 ] Add a numbering module to suggest automatically a product ref. - New: Add conditional substitution IF/ELSEIF/ENDIF for ODT templates. - New: Add unit foot2, inch2, foot3 and inch3 for surface and volumes. - New: Can select thirdparties into emailing targets, even if module category is not enabled. - New: [ task #498 ] Improvement of the block to add products/services lines. - New: ECM autodir works also for files joined to products and services. - New: Add a selection module for emailing to enter a recipient from gui. - New: Allow to search thirds and products from barcodes directly from the permanent mini search left box. - New: Allow to search product from barcodes directly from invoices, proposals... through AJAX. - New: Can make one invoice for several orders. - New: POS module can works with only one payment method (cach, chq, credit card). - New: Add possibility to defined position/job of a user. - New: Add hidden option to add slashes between lines into PDF. - New: [ task #210 ] Can choose cash account during POS login. - New: [ task #104 ] Can create an invoice from several orders. - New: Update libs/tools/logo for DoliWamp (now use PHP 5.3). - New: Added ODT Template tag {object_total_discount} - New: Add new import options: Third parties bank details, warehouses and stocks, categories and suppliers prices - New: English bank account need a bank code (called sort code) to identify an account. - New: Can choose menu entry to show with external site module. - New: Add hidden option MAIN_PDF_MARGIN_LEFT, MAIN_PDF_MARGIN_RIGHT, MAIN_PDF_MARGIN_TOP, MAIN_PDF_MARGIN_BOTTOM to force margins of generated PDF. - New: [ task #314 ] Can define if prof id are mandatory or not. - New: Add button on order card to create intervention from services. - New: Add search box to find products by supplier reference. - New: Add option MAIN_HELPCENTER_LINKTOUSE to define target link "I need help" onto logon page. - New: [ task #608 ] Can clone a supplier order with prices updates - New: [ task #559 ] Can define a discount % regarding quantity in supplier prices and price by quantity in customer prices - New: [ task #527 ] After cloning a suplier invoice, go onto invoice ref into edit mode
New experimental module:
- New: Add commissions management module.
- Fix: [ bug #499 ] Supplier order input method not translated - Fix: No images into product description lines as PDF generation does not work with this. - Fix: Errors weren't being shown in customer's & supplier's orders - Fix: Lastname wasn't being recorded in xinputuser emailing module. - Fix: [ bug #653 ] Error while creating agenda additional attributes - Fix: [ bug #654 ] Event rapport PDF showing ActionAC_OTH_AUTO - Fix: [ bug #658 ] Search on bank do not work for description - Fix: [ bug #659 ] Comment in recurrent invoices is not stored - Fix: [ bug #622 ] Attaching wrong file when sending the invoice via e-mail
For developers:
- New: Add webservice for thirdparty creation and list. - New: A module can overwrite templates parts. - New: Can add a link on title field of added dictionnary. - New: Uniformize code. - New: Add option WORKFLOW_DISABLE_CREATE_INVOICE_FROM_ORDER and WORKFLOW_DISABLE_CLASSIFY_BILLED_FROM_ORDER. - New: A module can add several css and js. - New: removed deprecated methods ldap::connect, formadmin::select_lang, html::select_tva - New: Add custom substitution function for ODT product lines: mymodule_completesubstitutionarray_lines() - New: Basic implementation of hooks and triggers for a lot (most) of core modules: action/calendar, trips and expenses, dons, vat payment, contact/society, contract, product lines, expedition, order supplier and order invoice (lines included), intervention card, project, tasks. - New: Add ChromePHP output into syslog module. - New: Add PRODUCT_PRICE_MODIFY trigger. - New: Created function to retrieve total amount of discount of an invoice/proposal... - New: We can use a dynamic value ($conf->global->XXX for example) into titles of menus. - Qual: Renamed SUPPLIER_INVOICE_BUILDDOC trigger to BILL_SUPPLIER_BUILDDOC - Qual: Renamed INVOICE_SUPPLIER_DELETE trigger to BILL_SUPPLIER_DELETE - Qual: Renamed SUPLIER_ORDER_BUILDDOC trigger to ORDER_SUPPLIER_BUILDDOC - Qual: Renamed CONTRACTLINE_DELETE trigger to CONTRACT_LINE_DELETE - Qual: Renamed all ficheinter.class.php triggers so that they start with 'FICHINTER_' - Fix: [ bug #655 ] ORDER_REOPEN trigger incorrectly named - Fix: [ bug #656 ] Contracts trigger CONTRACT_MODIFY incorrectly named - Fix: [ bug #657 ] Usergroup class' GROUP_DELETE trigger incorrectly named
For translators:
- New: Update language files (de, tr, pt, ca, es, en, fr). - New: Added bg_BG autotranslated language. - New: Translate the donation receipt.
