Roadmap and Release 3.3.0 ("gpl v3+" version)
Version: 3.3.0 (List of other versions on page Category:RoadMap)
Release date: January 2013
- Uniformizing of code
- War against major missing and not stable features
Detailed Changelog:
For users:
- New: Add holiday module, to declare and follow holidays of your employees. - New: Add margin management module. - New: Add new theme Amarok. - New: [ task #289 ] Can reorder tasks. - New: Add field "signature" into user card. If filled, text is added at end of predefined email texts. If option MAIN_MAIL_DO_NOT_USE_SIGN is on, this feature is disabled. - New: Can input a payment back onto an credit note. - New: Add link "Back to list" on all cards. - New: After first install, warning are visible onto mandatory setup not configured. Show also total number of activated modules. - New: Can filter list of proposal, order or invoice on sales representative. - New: Add supplier ref on supplier orders. - New: Can export supplier orders and customers shipments. - New: First change to install external plugins from gui (experimental). - New: Monaco is like France for default vat calculation - New: Can list elements (invoices, orders or proposals) on a particular
user contact). This allow to view a "basket" of its elements.
- New: Show bank account on payment list of invoice card. - New: Cloning project allow to clones task, notes, files, contacts. - New: Enhance default style. - New: Can edit and resiliate member status from list. - New: Can insert URL links into elements lines. Also reported into PDF. - New: When a member is validated, we can subscribe to mailing-lists according to its type. - New: Add a tab into members statistics to count members by nature. - New: Add link to third party into sells and purchase journal. - New: Suggest a method to generate a backup file for user with no access to mysqldump binary. - New: Can also use extrafields on contacts/addresses and users. - New: Support unique field for extrafields. - New: Extra fields supports more types (int, string, double, date, datetime). - New: Can correct stock of a warehouse from warehouse card. - New: [ task #185 ] Can input amount when correcting stock to recalculate PMP. - New: [ task #454 ] Add "No category" into filters on category. - New: Auto check box on page to edit interface options of user. - New: More surface control on stock correction page. - New: Add great britain provinces. - New: [ task #494 ] Send an email to foundation when a new member has auto-subscribed. - New: [ task #326 ] Add a numbering module to suggest automatically a product ref. - New: Add conditional substitution IF/ELSEIF/ENDIF for ODT templates. - New: Add unit foot2, inch2, foot3 and inch3 for surface and volumes. - New: Can select thirdparties into emailing targets, even if module category is not enabled. - New: [ task #498 ] Improvement of the block to add products/services lines. - New: ECM autodir works also for files joined to products and services. - New: Add a selection module for emailing to enter a recipient from gui. - New: Allow to search thirds and products from barcodes directly from the permanent mini search left box. - New: Allow to search product from barcodes directly from invoices, proposals... through AJAX. - New: Can make one invoice for several orders. - New: POS module can works with only one payment method (cach, chq, credit card). - New: Add possibility to defined position/job of a user. - New: Add hidden option to add slashes between lines into PDF. - New: [ task #210 ] Can choose cash account during POS login. - New: [ task #104 ] Can create an invoice from several orders. - New: Update libs/tools/logo for DoliWamp (now use PHP 5.3). - New: Added ODT Template tag {object_total_discount} - New: Add new import options: Third parties bank details, warehouses and stocks, categories and suppliers prices - New: English bank account need a bank code (called sort code) to identify an account. - New: Can choose menu entry to show with external site module. - New: Add hidden option MAIN_PDF_MARGIN_LEFT, MAIN_PDF_MARGIN_RIGHT, MAIN_PDF_MARGIN_TOP, MAIN_PDF_MARGIN_BOTTOM to force margins of generated PDF. - New: [ task #314 ] Can define if prof id are mandatory or not. - New: Add button on order card to create intervention from services. - New: Add search box to find products by supplier reference. - New: Add option MAIN_HELPCENTER_LINKTOUSE to define target link "I need help" onto logon page. - New: [ task #608 ] Can clone a supplier order with prices updates - New: [ task #559 ] Can define a discount % regarding quantity in supplier prices and price by quantity in customer prices - New: [ task #527 ] After cloning a suplier invoice, go onto invoice ref into edit mode
New experimental module:
- New: Add commissions management module.
- Fix: [ bug #499 ] Supplier order input method not translated - Fix: No images into product description lines as PDF generation does not work with this. - Fix: Errors weren't being shown in customer's & supplier's orders - Fix: Lastname wasn't being recorded in xinputuser emailing module. - Fix: [ bug #653 ] Error while creating agenda additional attributes - Fix: [ bug #654 ] Event rapport PDF showing ActionAC_OTH_AUTO - Fix: [ bug #658 ] Search on bank do not work for description - Fix: [ bug #659 ] Comment in recurrent invoices is not stored - Fix: [ bug #622 ] Attaching wrong file when sending the invoice via e-mail
For developers:
- New: Add webservice for thirdparty creation and list. - New: A module can overwrite templates parts. - New: Can add a link on title field of added dictionnary. - New: Uniformize code. - New: Add option WORKFLOW_DISABLE_CREATE_INVOICE_FROM_ORDER and WORKFLOW_DISABLE_CLASSIFY_BILLED_FROM_ORDER. - New: A module can add several css and js. - New: removed deprecated methods ldap::connect, formadmin::select_lang, html::select_tva - New: Add custom substitution function for ODT product lines: mymodule_completesubstitutionarray_lines() - New: Basic implementation of hooks and triggers for a lot (most) of core modules: action/calendar, trips and expenses, dons, vat payment, contact/society, contract, product lines, expedition, order supplier and order invoice (lines included), intervention card, project, tasks. - New: Add ChromePHP output into syslog module. - New: Add PRODUCT_PRICE_MODIFY trigger. - New: Created function to retrieve total amount of discount of an invoice/proposal... - New: We can use a dynamic value ($conf->global->XXX for example) into titles of menus. - Qual: Renamed SUPPLIER_INVOICE_BUILDDOC trigger to BILL_SUPPLIER_BUILDDOC - Qual: Renamed INVOICE_SUPPLIER_DELETE trigger to BILL_SUPPLIER_DELETE - Qual: Renamed SUPLIER_ORDER_BUILDDOC trigger to ORDER_SUPPLIER_BUILDDOC - Qual: Renamed CONTRACTLINE_DELETE trigger to CONTRACT_LINE_DELETE - Qual: Renamed all ficheinter.class.php triggers so that they start with 'FICHINTER_' - Fix: [ bug #655 ] ORDER_REOPEN trigger incorrectly named - Fix: [ bug #656 ] Contracts trigger CONTRACT_MODIFY incorrectly named - Fix: [ bug #657 ] Usergroup class' GROUP_DELETE trigger incorrectly named
For translators:
- New: Update language files (de, tr, pt, ca, es, en, fr). - New: Added bg_BG autotranslated language. - New: Translate the donation receipt.
Text to use to promote news
This is a sample of text used to announce this version.
Title
Dolibarr ERP & CRM 3.3 has been released.
Short article
The Dolibarr ERP & CRM 3.3 version is a major upgrade of previous version. More information on Dolibarr ERP & RM web site: http://www.dolibarr.org
Long Article
Dolibarr is a free modular software (you see only features you need) to manage small and medium companies, freelancers or foundations. It's an OpenSource software you can install on a web server or as a standalone software. Dolibarr is designed to provide simplicity:
- Simple to use (any module can be disabled to removed not required features, only the permissions features can not be disabled).
- Simple to install (with DoliWamp the auto-installer for Windows, DoliDeb, the auto-installer for Ubuntu/Debian, DoliRpm the auto-installer for Fedora-Redhat-Mandriva-Opensuse-Mageia or DoliMamp the auto-installer for Mac OS X, for people who don't know how to install an Apache server, MySQL or PHP. A simple web assistant is available for all other users).
- Simple for development (no heavy frameworks). Dolibarr, developed in PHP object, incorporates its own natural code, allowing every developer to be immediately operational, with no other knowledge than PHP).
Most important change into this versions are: ...
Note:
- Licence of Dolibarr has been changed from GNU GPL v2+ to GNU GPL v3+.
You can download 3.3 release candidate packages at https://sourceforge.net/projects/dolibarr/files/
A more complete list of changes is available into changelog at https://www.dolibarr.org/files/ChangeLog
