Roadmap and Release 8.0.0
Revision as of 09:43, 25 June 2019 by Eldy (talk | contribs)
Version: 8.0 (List of other versions on page Category:RoadMap)
Release date: August 2018
Module DAV, online payment process, supplier credit notes, standardization of code, VAT report rewriting
Detailed Changelog:
For Users: NEW: Experimental module: Ticket NEW: Experimental module: WebDAV NEW: Accept anonmymous events (no user assigned) NEW: Accountancy - Add import on general ledger NEW: Accountancy - Show journal name on journal page and hide button draft export (Add an option in admin) NEW: Can create event from record card of a company and member NEW: Add a button to create Stripe customer from the Payment mode tab NEW: Add accounting account number on product tooltip NEW: add any predefined mail content NEW: Add arrows to navigate into containers in website module NEW: Add a tab to specify accountant/auditor of the company NEW: Add Date delivery and Availability on Propals List NEW: Add date in goods reception supplier order table NEW: Add delivery_time_days of suppliers in export profile NEW: Add Docments'tab to expedition module NEW: Use dol_print_phone in thirdparty list page to format phone NEW: Add entry for the GDPR contact NEW: Add extrafield type "html" NEW: Add file number in accountant card and update export filename NEW: Add files management on products lot NEW: add filter on project task list NEW: Add hidden option COMPANY_AQUARIUM_CLEAN_REGEX to clean generated NEW: add internal stripe payment page for invoice NEW: Add key __USER_REMOTE_IP__ into available substitution variables NEW: Add link between credit note invoice and origin NEW: Add linked file tab to vat NEW: add link to stripe's info in bank menu NEW: Add margin filters NEW: Add mass action enable/disable on cron job list NEW: Add mass action on project's list to close projects NEW: Add method to register distributed payments on invoices NEW: Add multicurrency support for product buy price for supplier propales, orders and invoices NEW: Add name of day in the timesheet input page per day. NEW: add new parameters for tcpf encryption NEW: add optional esign field in pdf propal NEW: Add option BANK_ACCOUNT_ALLOW_EXTERNAL_DOWNLOAD NEW: Add option CONTRACT_SYNC_PLANNED_DATE_OF_SERVICES NEW: Add param $dolibarr_main_restrict_ip in config file to limit ips NEW: add pdf function to check if pdf file is protected/encrypted NEW: Add pdf template for stock/warehouse module NEW: Add phone format for a lot of countries NEW: Add product and product categories filters on customer margins NEW: Add product categories filter on product margin NEW: Add romanian chart of accounts NEW: Add stats in salaries module NEW: add stripe transaction NEW: Add tab contact on supplier proposals NEW: Add total of time spent in timespent page at top of page too. NEW: Add trigger CONTRACT_MODIFY NEW: Add triggers on ECM object and add fill src_object_type/id fields NEW: Add type of website container/page into dictionary NEW: advance target filtering can be used everywhere with tpl and fk_element NEW: Allow negative quantity for dispatch (supplier order) NEW: bank reconcile: checkbox to select all bank operations NEW: Better performance with openldap NEW: Can add filter actiontype and notactiontype on event ical export NEW: Can add product in supplier order/invoice even w/o predefined price NEW: cancel orders on massaction NEW: Can crop image files attached in "document" tabs of a member NEW: Can delete dir content in media and ECM module recursively NEW: Can dispatch if more than ordered (if hidden option set) NEW: Can edit the text color for title line of tables NEW: Can enter time spent from the list of time spent of project NEW: Can export leave requests NEW: Can filter on account range in general ledger grouped by account NEW: Can filter on country and taxid into the binding page NEW: Can filter on progression in timesheet NEW: Can fix the bank account of a payment if payment not conciliated NEW: Can force usage of shared link for photo of products NEW: Can get template of email from its label NEW: Can see Unit Purchase Value of product in stock movement NEW: Can select from the user list into send form email (For field to and CC) NEW: Can select sample to use when creating a new page NEW: can send mail from project card NEW: Can set position of images in module tickets NEW: Can set the reply-to into email sent NEW: Can set the start/end date of service line in invoice templates NEW: Can share any file from the "Document" tab. NEW: Can sort on priority in task scheduler list NEW: Can sort order of files in attach tab for leave and expensereport NEW: Can use setValueFrom without user modification field NEW: Cat set the encryption algorithm for extrafields of type password NEW: check idprof1 for country pt NEW: default add action: new param $backurlforcard to redirect to card NEW: default warehouse field for products + prefill warehouses when dispatching supplier orders NEW: Display price HT on all commercial area boards NEW: display total on contract service list NEW: display weight volume in proposal NEW: Edit of extrafields position page on the edit form NEW: Experimental DAV module provides a public and private directory NEW: export filter models can be share or not by user NEW: Externalsite module can accept iframe content. NEW: Filter export model is now by user NEW: Finish implementation of option PRODUIT_CUSTOMER_PRICES_BY_QTY_MULTIPRICES NEW: generalize use of button to create new element from list NEW: hidden conf AGENDA_NB_WEEKS_IN_VIEW_PER_USER to set nb weeks to show into per user view NEW: hidden conf to assign category to thirparty that are not customer nor prospect nor supplier NEW: hidden conf to set nb weeks to show into user view NEW: hidden option MAIN_DISABLE_FREE_LINES NEW: improve way of adding users/sales representative to thirdparty NEW: Introduce option THIRDPARTY_QUICKSEARCH_ON_FIELDS to personalize fields use to search on quick search. NEW: Introduce permission "approve" for "leave request" like for "expense report" NEW: Load product data optional fields to the line -> enables to use "line_options_{extrafield}" NEW: Look and feel v8 - Show Picto "+" on all links "Add record" NEW: Look and feel v8: Use a different picto for delete and unlink NEW: mail templates for projects NEW: Module variant supported on services NEW: monthly VAT report show "Claimed for the period" + "Paid during this NEW: Mutualize code for action="update_extras" NEW: On invoice card, show accounting account linked NEW: Online payment of invoice and subscription record the payment NEW: OnSearchAndListGoOnCustomerOrSupplierCard conf NEW: Optimize load of hooks classes (save 1-5Kb of memory) NEW: Option MAIN_SHOW_REGION_IN_STATE renamed into MAIN_SHOW_REGION_IN_STATE_SELECT are more complete NEW: Option to force all emails recipient NEW: Hidden option to send to salaries into emails forms NEW: order minimum amount NEW: add price in burger menu on mouvement list NEW: Report a list of leave requests for a month NEW: Section of files generated by mass action not visible if empty NEW: send mails from project card NEW: Show also size in bytes in tooltip if visible unit is not bytes NEW: Show keyboard shortcut of nav arrow into tooltip NEW: Show last result code of cron jobs in error in red NEW: Show region in company info & Global option to show state code MAIN_SHOW_STATE_CODE NEW: Show total number of records by category NEW: Show total of time consumed in week in time spent entry page NEW: Stripe online payments reuse the same stripe customer account NEW: Suggest link to pay online for customer orders NEW: supplier credit notes is now supported like for customer credit notes NEW: supplier order/order lines export: add supplier product ref NEW: supplier relative discounts NEW: Support alternative aliases of page name in website NEW: syslog file autoclean NEW: thirdparty categ filter on lists NEW: Use a css style for weekend in time spent NEW: Use common substitution rule for language to get translation in ODT NEW: Variable __ONLINE_PAYMENT_URL__ available in email templates
For developers: NEW: class reposition can also work on POST (not only GET) NEW: add a hook in dol_print_phone NEW: The field "visible" on extrafield can accept expression as condition NEW: Upgrade of Stripe lib to 6.4.1 NEW: work on CommonObject 'array' field typeNew common object array NEW: method Form::selectArrayFilter() + use in left menu search NEW: [REST API] Add the possibility to remove a category from a thirdparty NEW: doActions on categorycard NEW: add "moreHtmlRef" hook NEW: add hook for more permissions control NEW: add hook moreHtmlStatus to complete to status on banners NEW: Add hook printEmail NEW: Add hook setContentSecurityPolicy NEW: Add password_hash as a hash algorithm NEW: Add dol_is_link function NEW: Adds a contact to an invoice with REST API NEW: Adds a payment for the list of invoices given as parameter NEW: adds billing contacts ids to REST API returns NEW: Add showempty parameter in country selection NEW: add printUserListWhere hook NEW: add "printUserPasswordField" hooks NEW: Call to trigger on payment social contribution creation NEW: Call to trigger on social contribution creation NEW: hook getnomurltooltip is replaced with hook getNomUrl more powerfull
WARNING:
Following changes may create regressions for some external modules, but were necessary to make Dolibarr better:
  • Remove old deprecated hook 'insertExtraFields'. Triggers must be used for action on CRUD events.
  • Hook 'maildao' was renamed into 'mail' into the method sendfile that send emails, and method was renamed from 'doaction' into 'sendMail'.
  • Rename trigger CONTRACT_SERVICE_ACTIVATE into LINECONTRACT_ACTIVATE and CONTRACT_SERVICE_CLOSE into LINECONTRACT_CLOSE
  • Remove triggers *_CLONE. The trigger CREATE with context 'createfromclone' is already called so this is a duplicated feature. Cloning is not a business event, the business event is CREATE, so no trigger required.
  • PHP 5.3 is no more supported. Minimum PHP is now 5.4+
  • Remove the old deprecated code of doActions and getInstanceDao in canvas. The doActions of standard hooks are already available and are better.
  • Removed method fetch_prods() and get_each_prod() not used, keep only get_arbo_each_prod() that is better.
  • The hook contaxt commcard has been renamed thirdpartycomm
  • The hook contaxt thirdpartycard has been renamed thirdpartycontact
  • Remove method Categorie:get_nb_categories() that was not used.
  • Hook getnomurltooltip provide a duplicate feature compared to hook getNomUrl so all hooks getnomurltooltip are now replaced with hook getNomUrl.
