Roadmap and Release 9.0.0
Revision as of 14:10, 11 March 2019 by Framaurin (talk | contribs)
Version: 9.0 (List of other versions on page Category:RoadMap)
Release date: February 2019
Module DAV, Module social network rework, Module Website
Detailed Changelog:
***** ChangeLog for 9.0.0 compared to 8.0.0 *****
For Users:
NEW: Stable module: DAV (WebDAV only for the moment)
NEW: Stable module "Skype" has been replaced with module "Social Networks" to support more services.
NEW: Stable module "Module Builder"
NEW: Stable module: Website
NEW: Experimental module "TakePos"
NEW: Experimental module "Ticket"
NEW: Experimental module "Data Privacy"
NEW: Experimental module "Email Collector"
NEW: Dolibarr can provide information in page title when multicompany is enabled of not, making Android application like DoliDroid able to provide native features for multicompany module.
NEW: Compatibility with PHP 7.3 =>
NEW: Add admin page for modulebuilder
NEW: Add civility in list of members. Close #9251
NEW: Add configuration to disable "customer/prospect" thirdparty type
NEW: Add CONTRACT_ALLOW_TO_LINK_FROM_OTHER_COMPANY and CONTRACT_HIDE_UNSELECTABLES by SELECT_HIDE_UNSELECTABLES
NEW: Add __DAY_TEXT__ and __MONTH_TEXT__ substitutions vars
NEW: Add due date column in payment lists
NEW: Add email in event history, for reminder email of expired subsription
NEW: Add event tab on resource record
NEW: Add FEC Export in accountancy
NEW: Add filter on staff range in list of thirdparties
NEW: Add a first complete template of website
NEW: Add format code into exported filename of ledger
NEW: Add hidden option EXPENSEREPORT_DEFAULT_VALIDATOR_UNCHANGEABLE
NEW: Add hidden option MAIN_DOCUMENTS_DESCRIPTION_FIRST
NEW: Add link to inventory code
NEW: Add more common social networks fields for business
NEW: Add option PDF_DISABLE_MYCOMPANY_LOGO to disable logo on PDF
NEW: add option PROPOSAL_AUTO_ADD_AUTHOR_AS_CONTACT
NEW: Add option to display thirdparty adress in combolist
NEW: Add option to swap sender/recipient address on PDF
NEW: Add project on payment of salaries
NEW: Add SHIPPING_PDF_HIDE_WEIGHT_AND_VOLUME and
NEW: Add supplier ref in item reception page
NEW: Advanced permission to ignore price min
NEW: Allow to enter a timespent with a numeric value
NEW: Automatic position of scroll when creating an extrafield
NEW: Can add autorefresh=X in any URLs to refresh page after X seconds
NEW: can add project's task to agenda on create event form
NEW: Can delete a website in experimental website module
NEW: Can disable meteo on smartphone only
NEW: Can export/import a website template
NEW: Can filter on EEC, not EEC, etc... in binding step of accountancy
NEW: Can mix offset before and after with rules for due date of invoices
NEW: Can record the supplier product description
NEW: Can select several prospect level in thirdparty filter.
NEW: Can set 2 url in url field of thirdparty
NEW: Can set if a field is mandatory on form level.
NEW: Can set the default focus of each page.
NEW: Add category filter on user list
NEW: Change forgotten password link in general parameters
NEW: Child label of variants change if parent label changes
NEW: Compatibility with new Paybox HMAC requirement
NEW: Each user can set its prefered default calendar page
NEW: Enhancement in process to make manual bank conciliation
NEW: Enhancement in the generic file manager
NEW: Extrafield totalizable
NEW: Hidden conf INVOICE_USE_DEFAULT_DOCUMENT
NEW: hidden conf to search product by supplier ref
NEW: hidden constant to be able to use a thirdparty for donation
NEW: hidden option to define an invoice template for each invoice type
NEW: Highlight lines on lists when they are checked
NEW: Notification module support expense report+holiday validation and approval
NEW: On customer/supplier card, add simple tooltip to amount boxes
NEW: Page to check if the operations/items created between two dates have attached item(s) and possibility to download all attachements
NEW: possibility to add all rights of all modules in one time
NEW: redirect if only one result on global search on card
NEW: Permission to ignore price min
NEW: Can build an archive of full documents directory from backup page
NEW: tag odt line_product_ref_fourn for supplier doc lines
NEW: The binding step in accountancy has a country filter with autocompletion
NEW: Top menu is always on screen with MD theme.
NEW: Withdraw request massaction can include already partially paid invoices
NEW: Option "Simplify interface for blind persons"
NEW: Generic cash fence feature (compatible with several POS modules)
For developers:
NEW: Add lib for multiselect with checkboxes
NEW: Add function isValidMXRecord
NEW: Add somes hooks in bank planned entries
NEW: Add hook changeRoundingMode in update_price
NEW: Add hook formconfirm to contractcard
NEW: Add hook for virtual stock
NEW: ADD url to see the last version of a external module
NEW: Can enable a module, even external module, from command line
NEW: Can set a tooltip help text on extrafields
NEW: Add product search from barcode via REST api
NEW: can add documents on agenda events using API REST
NEW: Can set the datestart and dateend of cron job into module descriptor
NEW: Close #9296 Add field ref_ext into llx_categorie
NEW: move ticket dictionary in API /setup
NEW: PHPUnitTest on Loan class #3163
NEW: Code changes to be more compatible with PSR2
NEW: Removed trigger USER_LOGOUT, USER_LOGIN, USER_LOGIN_FAILED (Some hooks are already dedicated for that)
NEW: Add agenda documents in API REST
NEW: Add "checked" field for new list engine compatibility
NEW: REST API improvements
NEW: Save external payment IDs into table of payment
NEW: triggers add commercial and del commercial
NEW: #9236 Allow to import shipment lines via API
NEW: ADD civility list in API
NEW: support selllist in the  module builder
NEW: optional param to show a specific extrafield
NEW: hook formConfirm always called if hooked
NEW: hook on dispatch order fourn
WARNING:
Following changes may create regressions for some external modules, but were necessary to make Dolibarr better:
* If you use some links like viewimages.php?modulepart=mycompany&file=... in your external modules, you must
  replace them with links like viewimages.php?modulepart=mycompany&file=logos/... (note that link change only for
  modulepart=mycompany that now works like others).
* Hidden option MAIN_PDF_SHIPPING_DISPLAY_AMOUNT_HT has been renamed into SHIPPING_PDF_DISPLAY_AMOUNT_HT
* Remove the no more used and deprecated dol_print_graph function
