主模块代码框架
Revision as of 08:10, 16 January 2019 by R.ivnun (talk | contribs)
<?php
/*版权信息
 *Copyright (C) 2004-2018 Laurent Destailleur  <eldy@users.sourceforge.net>
 * Copyright (C) ---Put here your own copyright and developer email---
 * This program is free software; you can redistribute it and/or modify
 * it under the terms of the GNU General Public License as published by
 * the Free Software Foundation; either version 3 of the License, or
 * (at your option) any later version.
 * This program is distributed in the hope that it will be useful,
 * but WITHOUT ANY WARRANTY; without even the implied warranty of
 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 * GNU General Public License for more details.
 * You should have received a copy of the GNU General Public License
 * along with this program. If not, see <http://www.gnu.org/licenses/>.
 *  文档描述
 *  \defgroup   mymodule     Module MyModule
 *  \brief      MyModule module descriptor.
 *  模块文件的位置
 *  \file       htdocs/mymodule/core/modules/modMyModule.class.php
 *  \ingroup    mymodule
 *  \brief      Description and activation file for module MyModule
 //包含父类文件
include_once DOL_DOCUMENT_ROOT .'/core/modules/DolibarrModules.class.php';
// 类名,应以小写mod开头
// The class name should start with a lower case mod for Dolibarr to pick it up
// so we ignore the Squiz.Classes.ValidClassName.NotCamelCaps rule.
// @codingStandardsIgnoreStart
 *  描述并激活自定义类
 *  Description and activation class for module MyModule
class modMyModule extends DolibarrModules
	// @codingStandardsIgnoreEnd
	 * 构造器、定义名、结构、目录、信息框、权限
	 * Constructor. Define names, constants, directories, boxes, permissions
	 * @param DoliDB $db Database handler
	public function __construct($db)
	//加载全局变量 $langs,$conf
        global $langs,$conf;
        $this->db = $db;
		//模块ID(唯一)
		//Id for module (must be unique).
		// Use here a free id (See in Home -> System information -> Dolibarr for list of used modules id).
		$this->numero = 500000;		// TODO Go on page https://wiki.dolibarr.org/index.php/List_of_modules_id to reserve id number for your module
		//识别模块的关键字(为权限管理、目录等)
		//Key text used to identify module (for permissions, menus, etc...)
		$this->rights_class = 'mymodule';
		//家族分类,用来归类模块,于'主页'-'设置'-'模块'界面
		//Family can be 'crm','financial','hr','projects','products','ecm','technic','interface','other'
		// It is used to group modules by family in module setup page
		$this->family = "other";
		//模块在家族里的位置(2位数) Module position in the family on 2 digits ('01', '10', '20', ...)
		$this->module_position = '90';
		// Gives the possibility to the module, to provide his own family info and position of this family (Overwrite $this->family and $this->module_position. Avoid this)
		//$this->familyinfo = array('myownfamily' => array('position' => '01', 'label' => $langs->trans("MyOwnFamily")));
		// 模块标签(无空格)Module label (no space allowed), used if translation string 'ModuleMyModuleName' not found (MyModue is name of module).
		$this->name = preg_replace('/^mod/i','',get_class($this));
		// 模块描述Module description, used if translation string 'ModuleMyModuleDesc' not found (MyModue is name of module).
		$this->description = "MyModuleDescription";
		// Used only if file README.md and README-LL.md not found.
		$this->descriptionlong = "MyModuleDescription (Long)";
		$this->editor_name = 'Editor name';
		$this->editor_url = 'https://www.example.com';
		//版本名,可用的包括:Possible values for version are: 'development', 'experimental', 'dolibarr', 'dolibarr_deprecated' or a version string like 'x.y.z'
		$this->version = '1.0';
		// Key used in llx_const table to save module status enabled/disabled (where MYMODULE is value of property name of module in uppercase)
		$this->const_name = 'MAIN_MODULE_'.strtoupper($this->name);
		// 模块的图像文件名Name of image file used for this module.
		// If file is in theme/yourtheme/img directory under name object_pictovalue.png, use this->picto='pictovalue'
		// If file is in module/img directory under name object_pictovalue.png, use this->picto='pictovalue@module'
		$this->picto='generic';
		// 定义所有模块组成。Defined all module parts (triggers, login, substitutions, menus, css, etc...)
		// for default path (eg: /mymodule/core/xxxxx) (0=disable, 1=enable)
		// for specific path of parts (eg: /mymodule/core/modules/barcode)
		// for specific css file (eg: /mymodule/css/mymodule.css.php)
		$this->module_parts = array(
		                        	'triggers' => 1,                                 	// Set this to 1 if module has its own trigger directory (core/triggers)
						'login' => 0,                                    	// Set this to 1 if module has its own login method file (core/login)
						'substitutions' => 1,                            	// Set this to 1 if module has its own substitution function file (core/substitutions)
						'menus' => 0,                                    	// Set this to 1 if module has its own menus handler directory (core/menus)
						'theme' => 0,                                    	// Set this to 1 if module has its own theme directory (theme)
		                        	'tpl' => 0,                                      	// Set this to 1 if module overwrite template dir (core/tpl)
						'barcode' => 0,                                  	// Set this to 1 if module has its own barcode directory (core/modules/barcode)
						'models' => 0,                                   	// Set this to 1 if module has its own models directory (core/modules/xxx)
						'css' => array('/mymodule/css/mymodule.css.php'),	// Set this to relative path of css file if module has its own css file
	 					'js' => array('/mymodule/js/mymodule.js.php'),          // Set this to relative path of js file if module must load a js on all pages
						'hooks' => array('data'=>array('hookcontext1','hookcontext2'), 'entity'=>'0') 	// Set here all hooks context managed by module. To find available hook context, make a "grep -r '>initHooks(' *" on source code. You can also set hook context 'all'
		// 数据目录,Data directories to create when module is enabled.
		// Example: this->dirs = array("/mymodule/temp","/mymodule/subdir");
		$this->dirs = array();
		// 设置页面,Config pages. Put here list of php page, stored into mymodule/admin directory, to use to setup module.
		$this->config_page_url = array("setup.php@mymodule");
		// Dependencies
		$this->hidden = false;			// A condition to hide module
		$this->depends = array();		// List of module class names as string that must be enabled if this module is enabled
		$this->requiredby = array();	// List of module ids to disable if this one is disabled
		$this->conflictwith = array();	// List of module class names as string this module is in conflict with
		$this->langfiles = array("mymodule@mymodule");
		$this->phpmin = array(5,3);					// Minimum version of PHP required by module
		$this->need_dolibarr_version = array(4,0);	// Minimum version of Dolibarr required by module
		$this->warnings_activation = array();                     // Warning to show when we activate module. array('always'='text') or array('FR'='textfr','ES'='textes'...)
		$this->warnings_activation_ext = array();                 // Warning to show when we activate an external module. array('always'='text') or array('FR'='textfr','ES'='textes'...)
		//$this->automatic_activation = array('FR'=>'MyModuleWasAutomaticallyActivatedBecauseOfYourCountryChoice');
		//$this->always_enabled = true;								// If true, can't be disabled
		// 常量,Constants
		// List of particular constants to add when module is enabled (key, 'chaine', value, desc, visible, 'current' or 'allentities', deleteonunactive)
		// Example: $this->const=array(0=>array('MYMODULE_MYNEWCONST1','chaine','myvalue','This is a constant to add',1),
		//                             1=>array('MYMODULE_MYNEWCONST2','chaine','myvalue','This is another constant to add',0, 'current', 1)
		$this->const = array(
			1=>array('MYMODULE_MYCONSTANT', 'chaine', 'avalue', 'This is a constant to add', 1, 'allentities', 1)
		if (! isset($conf->mymodule) || ! isset($conf->mymodule->enabled))
			$conf->mymodule=new stdClass();
			$conf->mymodule->enabled=0;
		// 增加选项卡,Array to add new pages in new tabs
        $this->tabs = array();
		// Example:
		// $this->tabs[] = array('data'=>'objecttype:+tabname1:Title1:mylangfile@mymodule:$user->rights->mymodule->read:/mymodule/mynewtab1.php?id=__ID__');  					// To add a new tab identified by code tabname1
        // $this->tabs[] = array('data'=>'objecttype:+tabname2:SUBSTITUTION_Title2:mylangfile@mymodule:$user->rights->othermodule->read:/mymodule/mynewtab2.php?id=__ID__',  	// To add another new tab identified by code tabname2. Label will be result of calling all substitution functions on 'Title2' key.
        // $this->tabs[] = array('data'=>'objecttype:-tabname:NU:conditiontoremove');                                                     										// To remove an existing tab identified by code tabname
        // Where objecttype can be
		// 'categories_x'	  to add a tab in category view (replace 'x' by type of category (0=product, 1=supplier, 2=customer, 3=member)
		// 'contact'          to add a tab in contact view
		// 'contract'         to add a tab in contract view
		// 'group'            to add a tab in group view
		// 'intervention'     to add a tab in intervention view
		// 'invoice'          to add a tab in customer invoice view
		// 'invoice_supplier' to add a tab in supplier invoice view
		// 'member'           to add a tab in fundation member view
		// 'opensurveypoll'	  to add a tab in opensurvey poll view
		// 'order'            to add a tab in customer order view
		// 'order_supplier'   to add a tab in supplier order view
		// 'payment'		  to add a tab in payment view
		// 'payment_supplier' to add a tab in supplier payment view
		// 'product'          to add a tab in product view
		// 'propal'           to add a tab in propal view
		// 'project'          to add a tab in project view
		// 'stock'            to add a tab in stock view
		// 'thirdparty'       to add a tab in third party view
		// 'user'             to add a tab in user view
        // 字典,Dictionaries
		$this->dictionaries=array();
        /* Example:
            'langs'=>'mylangfile@mymodule',
            'tabname'=>array(MAIN_DB_PREFIX."table1",MAIN_DB_PREFIX."table2",MAIN_DB_PREFIX."table3"),		// List of tables we want to see into dictonnary editor
            'tablib'=>array("Table1","Table2","Table3"),													// Label of tables
            'tabsql'=>array('SELECT f.rowid as rowid, f.code, f.label, f.active FROM '.MAIN_DB_PREFIX.'table1 as f','SELECT f.rowid as rowid, f.code, f.label, f.active FROM '.MAIN_DB_PREFIX.'table2 as f','SELECT f.rowid as rowid, f.code, f.label, f.active FROM '.MAIN_DB_PREFIX.'table3 as f'),	// Request to select fields
            'tabsqlsort'=>array("label ASC","label ASC","label ASC"),																					// Sort order
            'tabfield'=>array("code,label","code,label","code,label"),																					// List of fields (result of select to show dictionary)
            'tabfieldvalue'=>array("code,label","code,label","code,label"),																				// List of fields (list of fields to edit a record)
            'tabfieldinsert'=>array("code,label","code,label","code,label"),																			// List of fields (list of fields for insert)
            'tabrowid'=>array("rowid","rowid","rowid"),																									// Name of columns with primary key (try to always name it 'rowid')
            'tabcond'=>array($conf->mymodule->enabled,$conf->mymodule->enabled,$conf->mymodule->enabled)												// Condition to show each dictionary
        // 信息框/插件,Boxes/Widgets
		// Add here list of php file(s) stored in mymodule/core/boxes that contains class to show a widget.
        $this->boxes = array(
        	0=>array('file'=>'mymodulewidget1.php@mymodule','note'=>'Widget provided by MyModule','enabledbydefaulton'=>'Home'),
        	//1=>array('file'=>'mymodulewidget2.php@mymodule','note'=>'Widget provided by MyModule'),
        	//2=>array('file'=>'mymodulewidget3.php@mymodule','note'=>'Widget provided by MyModule')
		// Cronjobs (List of cron jobs entries to add when module is enabled)
		// unit_frequency must be 60 for minute, 3600 for hour, 86400 for day, 604800 for week
		$this->cronjobs = array(
			0=>array('label'=>'MyJob label', 'jobtype'=>'method', 'class'=>'/mymodule/class/myobject.class.php', 'objectname'=>'MyObject', 'method'=>'doScheduledJob', 'parameters'=>'', 'comment'=>'Comment', 'frequency'=>2, 'unitfrequency'=>3600, 'status'=>0, 'test'=>true)
		// Example: $this->cronjobs=array(0=>array('label'=>'My label', 'jobtype'=>'method', 'class'=>'/dir/class/file.class.php', 'objectname'=>'MyClass', 'method'=>'myMethod', 'parameters'=>'param1, param2', 'comment'=>'Comment', 'frequency'=>2, 'unitfrequency'=>3600, 'status'=>0, 'test'=>true),
		//                                1=>array('label'=>'My label', 'jobtype'=>'command', 'command'=>'', 'parameters'=>'param1, param2', 'comment'=>'Comment', 'frequency'=>1, 'unitfrequency'=>3600*24, 'status'=>0, 'test'=>true)
		// Permissions
		$this->rights = array();		// Permission array used by this module
		$r=0;
		$this->rights[$r][0] = $this->numero + $r;	// Permission id (must not be already used)
		$this->rights[$r][1] = 'Read myobject of MyModule';	// Permission label
		$this->rights[$r][3] = 1; 					// Permission by default for new user (0/1)
		$this->rights[$r][4] = 'read';				// In php code, permission will be checked by test if ($user->rights->mymodule->level1->level2)
		$this->rights[$r][5] = '';				    // In php code, permission will be checked by test if ($user->rights->mymodule->level1->level2)
		$r++;
		$this->rights[$r][1] = 'Create/Update myobject of MyModule';	// Permission label
		$this->rights[$r][4] = 'write';				// In php code, permission will be checked by test if ($user->rights->mymodule->level1->level2)
		$r++;
		$this->rights[$r][1] = 'Delete myobject of MyModule';	// Permission label
		$this->rights[$r][4] = 'delete';				// In php code, permission will be checked by test if ($user->rights->mymodule->level1->level2)
		// 主菜单条目 Main menu entries
		$r=0;
		// 增加菜单条目,Add here entries to declare new menus
		/* 项部菜单,BEGIN MODULEBUILDER TOPMENU */
		$this->menu[$r++]=array('fk_menu'=>'',			                // '' if this is a top menu. For left menu, use 'fk_mainmenu=xxx' or 'fk_mainmenu=xxx,fk_leftmenu=yyy' where xxx is mainmenucode and yyy is a leftmenucode
								'type'=>'top',			                // This is a Top menu entry
								'titre'=>'MyModule',
								'mainmenu'=>'mymodule',
								'leftmenu'=>'',
								'url'=>'/mymodule/mymoduleindex.php',
								'langs'=>'mymodule@mymodule',	        // Lang file to use (without .lang) by module. File must be in langs/code_CODE/ directory.
								'position'=>1000+$r,
								'enabled'=>'$conf->mymodule->enabled',	// Define condition to show or hide menu entry. Use '$conf->mymodule->enabled' if entry must be visible if module is enabled.
								'perms'=>'1',			                // Use 'perms'=>'$user->rights->mymodule->level1->level2' if you want your menu with a permission rules
								'target'=>'',
								'user'=>2);				                // 0=Menu for internal users, 1=external users, 2=both
		/* 项部菜单结束,END MODULEBUILDER TOPMENU */
		/* 对象左侧菜单开始,BEGIN MODULEBUILDER LEFTMENU MYOBJECT
		$this->menu[$r++]=array(	'fk_menu'=>'fk_mainmenu=mymodule',	    // '' if this is a top menu. For left menu, use 'fk_mainmenu=xxx' or 'fk_mainmenu=xxx,fk_leftmenu=yyy' where xxx is mainmenucode and yyy is a leftmenucode
								'type'=>'left',			                // This is a Left menu entry
								'titre'=>'List MyObject',
								'leftmenu'=>'mymodule_myobject_list',
								'url'=>'/mymodule/myobject_list.php',
								'enabled'=>'$conf->mymodule->enabled',  // Define condition to show or hide menu entry. Use '$conf->mymodule->enabled' if entry must be visible if module is enabled. Use '$leftmenu==\'system\'' to show if leftmenu system is selected.
								'target'=>'',
		$this->menu[$r++]=array(	'fk_menu'=>'fk_mainmenu=mymodule,fk_leftmenu=mymodule',	    // '' if this is a top menu. For left menu, use 'fk_mainmenu=xxx' or 'fk_mainmenu=xxx,fk_leftmenu=yyy' where xxx is mainmenucode and yyy is a leftmenucode
								'titre'=>'New MyObject',
								'leftmenu'=>'mymodule_myobject_new',
								'url'=>'/mymodule/myobject_page.php?action=create',
								'target'=>'',
		END MODULEBUILDER LEFTMENU MYOBJECT */
		// Exports
		$r=1;
		/* BEGIN MODULEBUILDER EXPORT MYOBJECT */
		$langs->load("mymodule@mymodule");
		$this->export_code[$r]=$this->rights_class.'_'.$r;
		$this->export_label[$r]='MyObjectLines';	// Translation key (used only if key ExportDataset_xxx_z not found)
		$this->export_icon[$r]='myobject@mymodule';
		$keyforclass = 'MyObject'; $keyforclassfile='/mymobule/class/myobject.class.php'; $keyforelement='myobject';
		include DOL_DOCUMENT_ROOT.'/core/commonfieldsinexport.inc.php';
		$keyforselect='myobject'; $keyforaliasextra='extra'; $keyforelement='myobject';
		include DOL_DOCUMENT_ROOT.'/core/extrafieldsinexport.inc.php';
		//$this->export_dependencies_array[$r]=array('mysubobject'=>'ts.rowid', 't.myfield'=>array('t.myfield2','t.myfield3')); // To force to activate one or several fields if we select some fields that need same (like to select a unique key if we ask a field of a child to avoid the DISTINCT to discard them, or for computed field than need several other fields)
		$this->export_sql_start[$r]='SELECT DISTINCT ';
		$this->export_sql_end[$r]  =' FROM '.MAIN_DB_PREFIX.'myobject as t';
		$this->export_sql_end[$r] .=' WHERE 1 = 1';
		$this->export_sql_end[$r] .=' AND t.entity IN ('.getEntity('myobject').')';
		$r++; */
		/* END MODULEBUILDER EXPORT MYOBJECT */
	 *	Function called when module is enabled.
	 *	The init function add constants, boxes, permissions and menus (defined in constructor) into Dolibarr database.
	 *	It also creates data directories
     *	@param      string	$options    Options when enabling module ('', 'noboxes')
	 *	@return     int             	1 if OK, 0 if KO
	public function init($options='')
		// Create extrafields
		include_once DOL_DOCUMENT_ROOT.'/core/class/extrafields.class.php';
		$extrafields = new ExtraFields($this->db);
		//$result1=$extrafields->addExtraField('myattr1', "New Attr 1 label", 'boolean', 1,  3, 'thirdparty',   0, 0, '', '', 1, '', 0, 0, '', '', 'mymodule@mymodule', '$conf->mymodule->enabled');
		//$result2=$extrafields->addExtraField('myattr2', "New Attr 2 label", 'varchar', 1, 10, 'project',      0, 0, '', '', 1, '', 0, 0, '', '', 'mymodule@mymodule', '$conf->mymodule->enabled');
		//$result3=$extrafields->addExtraField('myattr3', "New Attr 3 label", 'varchar', 1, 10, 'bank_account', 0, 0, '', '', 1, '', 0, 0, '', '', 'mymodule@mymodule', '$conf->mymodule->enabled');
		//$result4=$extrafields->addExtraField('myattr4', "New Attr 4 label", 'select',  1,  3, 'thirdparty',   0, 1, '', array('options'=>array('code1'=>'Val1','code2'=>'Val2','code3'=>'Val3')), 1 '', 0, 0, '', '', 'mymodule@mymodule', '$conf->mymodule->enabled');
		//$result5=$extrafields->addExtraField('myattr5', "New Attr 5 label", 'text',    1, 10, 'user',         0, 0, '', '', 1, '', 0, 0, '', '', 'mymodule@mymodule', '$conf->mymodule->enabled');
		$sql = array();
		return $this->_init($sql, $options);
	 *	Function called when module is disabled.
	 *	Remove from database constants, boxes and permissions from Dolibarr database.
	 *	Data directories are not deleted
	public function remove($options = '')
		$sql = array();
		return $this->_remove($sql, $options);
