Module KanView (Kanban views for Dolibarr)
Revision as of 17:56, 9 September 2018 by ElkoulaniM (talk | contribs)
The KanView module for Dolibarr manages a set of Kanban views for Dolibarr elements (Projects, Tasks, Propals, Orders, Invoices, ...) It allows to visualize the current states of these elements in columns and makes it possible to pass an element from a state to another by simple Drag & Drop from one column to the other when the Dolibarr business rules allow it. Each element is represented by a small card (also called tile) that appears in the column representing its current state.
The installation of the KanView module is like any other Dolibarr module. When you get the module zip, unzip it in htdocs or htdocs / custom. Then go to Home / Configuration / Modules. Look for the KanView module in the "Multi-Module Tools" category with the label "KanView" or "Kanban Views"
After module activation, a top menu entry "KanView" is added to the Dolibarr menus
Kanban views availables
- Projects
- Tasks
- Prospects
- Propals
- Orders
- Invoices
