<keywords content="prestashop, shop, webservice, api"/>
Information
Module name | PrestaShopToDolibarr |
Editor / Editeur | |
Download or buy page / Page achat ou téléchargement | External module - https://www.dolistore.com/fr/modules/497-Prestashop-to-Dolibarr-PRO.html |
Prerequisites / Prérequis |
Dolibarr max version: See on Dolistore |
Last update date / Date mise à jour fiche / Fecha última actualización | 2018-09-6 |
Note / Nota |
Synchronise its Prestashop to Dolibarr.
From the application
Manually
unzip modulefile.zip
- GIT Repository: https://github.com/johanbernard/prestashop_to_dolibarr
Please submit your PR to this repository if you make enhancements to this module.
