Module PrestaShop To Dolibarr
Revision as of 15:54, 6 September 2018 by Eldy (talk | contribs)
<keywords content="prestashop, shop, webservice, api"/>
Module name PrestaShopToDolibarr
Editor / Editeur
Dolibarr max version: {{{maxversion}}}
Last update date / Date mise à jour fiche / Fecha última actualización 2018-09-6
Synchronise its Prestashop to Dolibarr.
From the application
Manually
unzip modulefile.zip
Please submit your PR to this repository if you make enhancements to this module.
