Module PrestaShop To Dolibarr
Revision as of 15:49, 6 September 2018 by Eldy (talk | contribs) (Created page with "Category:Modules complémentaires <keywords content="prestashop, shop, webservice, api"/> = Informations = {{TemplateModuleInfo |modulename=PrestaShopToDolibarr |editor= |we...")
Module name PrestaShopToDolibarr
Editor / Editeur
Dolibarr max version: {{{maxversion}}}
Last update date / Date mise à jour fiche / Fecha última actualización 2018-09-6
Synchronise its Prestashop to Dolibarr.
From the application
Manually
unzip modulefile.zip
