Module KMGArchiGED EN
Revision as of 10:16, 6 September 2018 by Guerrier.k (talk | contribs) (→‎Configuration: Traduction)
version 1.41 - 01/09/2018
Module name Module KMGArchiGED
Editor / Editeur Kevin GUERRIER
Download or buy page / Page achat ou téléchargement External module - Dolistore
Dolibarr min version: See on Dolistore
Last update date / Date mise à jour fiche / Fecha última actualización 2018-09-6
Note / Nota In Progress - Access to French version : Documentation FR
Preamble
The KMGArchiGED module has been developed to allow the management of incoming documents within a structure, their reception from a scanning device managing the sending via FTP, their transmission by email, their link with native elements of Dolibarr, as well as than their archiving.
The use case at the origin of the module is the following :
  • The mails are received by the secretariat which has a network scanner on which shortcuts have been configured :
    • Suppliers Invoices
    • Bank Documents
    • Social Document
    • Dues and taxes
    • Others mails
  • Depending on the documents, the person sends the items to the correct bib, checks that the document has been correctly transmitted from the module, and then stores the paper documents.
  • Processing can be done directly by staff members within different departments directly from the module.
For example :
  • Supplier invoices can be entered from the preview and the document can be directly linked to ;
  • Social documents or tax correspondence can be sent by e-mail to the accountant for further information ;
  • Customer payment notices can be used to enter payments with correct lettering and the document can be linked to the third party to maintain traceability ;
  • Statements of account can be attached to the corresponding bank account ;
  • The worksheets, followed by interventions, activity reports, ... can be attached to the projects and tasks concerned ;
The installation archive contains a kmgarchiged folder containing all the files required for the proper functioning of the module. In order to be activated in the modules configuration interface, the kmgarchiged folder must be copied to either the htdocs directory or the htdocs/custom directory.
Note that the use of the htdocs/custom directory requires that the parameters
$dolibarr_main_url_root_alt
and
$dolibarr_main_document_root_alt
has been correctly defined.
Once this file has been transmitted, the module can be activated from the module configuration interface of your Dolibarr instance (Home > Configuration > Modules).
Once the module is installed, access to the configuration is done by the icon ending line.
Event Types Section
The KMGArchiGED module automatically generates events in the calendar when a user processes a document. It is possible to create specific event codes for deleting, linking, notifying a document from the module, or for receiving a document in the module. If these types of events are not present in your instance of Dolibarr, it is possible to create it by using the "Add" button. Otherwise, the event type AC_OTH_AUTO, which defines the "Events inserted automatically" will be used.
Email section
If the sending by email is correctly configured on your Dolibarr instance, it is possible to transmit a document present in a banner by email. Pre-filled information is customizable in this section. In any case, the user can modify the elements before each sending.
Tools section
The KMGArchiGED module uses functions external to the Dolibarr engine and therefore requires the use of external tools. To date, only the convert command is used, in particular to generate the preview images of a document. This order is present on most of the accommodations. If you encounter a problem viewing a preview of a document when viewing a mail bin, please check that the convert command is found by the module in this section.
If this command is not found, it is necessary to install (or activate) it on your server. If, despite this, the problem persists, please contact our support.
Links section for direct sending by FTP
This section details the paths to the available bins, information needed to configure network devices for FTP document transmission (see below: Features > Transmitting a document by FTP). They must of course be adapted according to your configuration.
Accès aux bannettes virtuelles
Les documents peuvent être transmis dans une “bannette virtuelle”. L’accès à chacune de ces bannette est subordonné à des permissions des modules Dolibarr. Par défaut, les bannettes suivantes sont disponibles :
Tableau
Bannette virtuelle Module Permission
Factures Fournisseurs
Fournisseurs
Consulter les factures fournisseur
Documents Sociaux
Dépenses spéciales
Lire les charges fiscales ou sociales et paiement de TVA
Impôts et taxes
Documents Bancaires
Banques et caisses
Consulter les comptes financiers
Autres
KMGArchiGED
Utiliser Kmgarchiged
A noter que le rôle administrateur permet l’accès à l’ensemble des bannettes virtuelles.
Si vous pensez à d’autres bannettes ou si votre fonctionnement nécessite l’utilisation de bannettes spécifiques, n’hésitez pas à nous contacter.
Transmission d’un document via FTP
Cette fonctionnalité nécessite que le répertoire document ainsi que son contenu soient accessibles via FTP. Cette fonctionnalité est accessible pour la majorité des hébergements. Les informations de connexion (adresse d’accès, utilisateur et mot de passe) seront nécessaires pour configurer le périphérique de numérisation (Copieur, Imprimante multifonctions, Scanner réseau, …). Il est possible de paramétrer des raccourcis pour une bannette virtuelle en adaptant le chemin d’accès.
Vous trouverez ci-après un exemple de configuration pour un raccourci direct vers les “Factures fournisseurs”.
Informations concernant la connexion FTP
  • Adresse du serveur FTP : ftp.mon-serveur.net
  • Nom d’utilisateur : monUser
  • Mot de passe : monPass
  • Racine FTP : Dans le dossier contenant les répertoires htdocs et documents de Dolibarr
Configuration du raccourci (issu d’un Xerox WorkCentre 6515DN MFP)
  • Nom d'hôte : ftp.mon-serveur.net
  • Chemin du document : /documents/kmgarchiged/SupplierInvoices
  • Nom de connexion : monUser
  • Confirmer le mot de passe : monPass
Comme vu précédemment, les informations relatives aux différentes bannettes disponibles sont précisées dans la page de configuration du module. Ils doivent bien sûr être adaptés selon votre configuration.
Le module KMGArchiGED est prévu pour fonctionner avec les fichiers au format PDF. La plein compatibilité du module avec l’utilisation d’autres formats n’est pas garantie. Si vous souhaitez prendre en charge des types de fichiers particuliers, n’hésitez pas à nous contacter.
Transmission d’un document via upload direct
L’interface principale du module liste les bannettes disponibles pour l’utilisateur en fonction de ces droits. Pour chacune de ces bannettes, la liste des documents présents est affichée, et sous cette liste, une section permet à l’utilisateur d’ajouter un nouveau document.
Consultation et gestion des documents d’une bannette
Un document présent dans une bannette est affiché de la manière suivante :
  • Le lien de prévisualisation du document complet (icone fichier avec loupe) ainsi que la date à laquelle le document à été vu pour la première fois par le module sont affichés en entête. Une image représentant le premier tiers de la première page du document est affichée en dessous, suivie de la liste des événements déjà réalisés pour ce document.
  • La partie droite permet :
    • de transmettre par email le document à un tiers, à un contact, à un utilisateur, ou directement à une adresse mail. Le sujet et le corps du mail sont pré-remplis et peuvent être ajustés par l’utilisateur avant envoi. Dans le cas où le document est transmis à un utilisateur ayant accès au module KMGArchiGED, un lien direct permettant d’accéder au document et au module est ajouté dans le corps du mail ;
    • de lier le document à un élément natif de Dolibarr (parmis Tiers, Banque, Propale Client, Commande Client, Facture Client, Commande Fournisseur, Facture Fournisseur, Projet, Tâche, Charge Sociale), avec la possibilité de le renommer au passage (l’extension ne doit pas être précisée dans le nouveau nom. Elle est reprise automatiquement) ;
    • d’archiver un document pour lequel plus aucune action n’est requise ;
Si vous souhaitez lier un document à d’autres types d’éléments (natifs ou issus d’un module externe) ou si vous souhaitez une autre fonctionnalité, n’hésitez pas à nous contacter.
Consultation des documents archivés
Une fois archivé, les documents sont accessibles depuis le menu KMGArchiGED > Archives. Cette interface liste les documents en fonction de la période à laquelle ils ont été reçus dans le module (filtre au trimestre, scindé par semaine et par bannette).
Les documents sont listés les uns en dessous des autre, et sont précédés d’un lien de prévisualisation du document complet (icone fichier avec loupe). Le nom du document est cliquable afin de télécharger directement le fichier. A noter que les bannettes disponibles dépendent également des permissions accordées à l’utilisateur.
Si vous souhaitez réaliser des actions complémentaires au sein de ces archives ou si vous souhaitez une autre fonctionnalité, n’hésitez pas à nous contacter.
Développement & Support
Ce module est développé et maintenu par Kevin GUERRIER. Toute demande de renseignement, question technique, proposition d’amélioration, remontée d’anomalie, … doit être transmise par mail à l’adresse support[at]kmg-process.com.
