Versions
- Dolibarr must work on:
- All OS (Windows, Linux, MACOS...)
- PHP 7.1.0+ (Must work with no need of complementary PHP module, except module to PHP module to access database).
- Mysql 5.1+
Copyright Norms
- All PHP files must start with a header that looks like
<?php
* Licence information
PHP Norms
PHP
- Dolibarr is written with PHP and supports all versions of PHP higher than 7.1.0+. All files must end with extension .php
- Usage of PHP superglobals variables must use the dedicated operators $_COOKIES, $_SERVER, $_ENV but use the Dolibarr function GETPOST() to get the contents of $_GET or $_POST..
Other operators ($HTTP_SERVER_GET, ...) are now deprecated in PHP, so they must not be used. Code must work if option register_long_arrays is set to off. Moreover, the code must work when PHP option register_globals is off (recommended by PHP). It must also work the if the option register_globals is on (by default on a lot of installations).
- Do not use PHP_SELF. Use instead $_SERVER["PHP_SELF"]. Also, Dolibarr framework sanitizes content of $_SERVER["PHP_SELF"] variable (into main.inc.php file, before any business code).
- When several variables must be initialized with the same value, you must use individual declarations (separated by ;)
$var1=1;
$var2=1;
$var3=1;
instead of
$var1=$var2=$var3=1;
which is slower.
- Strings must be delimited by a single or double quote and a variable within the string must be outside of the quote.
print 'My text show my '.$variable.' !';
- Comments must use the C syntax, ie a double slash for a comment on one line and a slash-star to open a bloc for several lines
/* Bloc of comment
* End of bloc
// comment on one line
print $i;
// code
- Functions must return a value equal or higher than 0 if successful and strictly lower than 0 if error.
- No dead code (code never used) into Dolibarr core code (code used by external modules only must be included within the external modules).
- Use "include_once" for anything with functions or class definitions in it (like *.class.php and *.lib.php files), use "include" for template-style php with files containing common part of HTML and PHP code (like *.inc.php and *.tpl.php files).
- Coding style to use is the PSR-2 (https://github.com/php-fig/fig-standards/blob/master/accepted/PSR-2-coding-style-guide.md). Only rules tagged "MUST" are currently required. So note however the exceptions:
- Length of line: PSR-2 mention we can't go up to 120 characters on same line, this is a soft limit. It is better to have long lines instead of long page with code content that is just data declaration and does not contain any logic. However, we introduced a hard limit of 1000 characters (having line larger than this may return errors on Continuous Integration tests).
- Tabs are allowed: The other exception is that we don't replace systematically the tabs with spaces. Using tabs is more convenient for most editors/developers. Also using spaces breaks some auto-format features (like Eclipse autoformat feature on some Eclipse version). For the moment, the best setup is "Keep spaces/tabs as it is", however, you can activate the option "Remove spaces at end of lines".
- Note 1: The following rule are very important to follow:
- Files must be saved with Unix format (LF) and not Windows (CR/LF). Unix format is compatible on all OS such as Unix like, Windows, Mac, but the Windows text file format may not work on some PHP under Unix.
- Smart tags PHP are not used. PHP code section must start with <?php
- Note 2: You can use the file dev/codesniffer/ruleset.xml as rule file to control coding style with PHPCodeSniffer.
- Note 3: You may note that current code is not yet compliant with the PSR-2. The reason is that we must "now" follow the "MUST" rules of PSR-2, but it wasn't in the past. So feel free to change coding style to match new rules (keep in mind the 2 exceptions) if you find such cases.
- entity that is id for the multicompany feature - date_creation: date of creation - date_modification: date of last modification (often field tms in database) - date_validation: date validation - fk_user_creation: id of User of creation - fk_user_modification: id of User of last modification - fk_user_validation: id of User of validation - import_key contains the import code YYYYMMDDHHMMSS, if record was loaded with a mass import.
SQL rules
DDL file format
- The first file defines the table and its fields. The file name contains the table name, e.g. like this: llx_mytable.sql
- The second file defines all foreign keys, performance indexes or other constraints and the file name will be like: llx_mytable.key.sql
create table llx_mytable
field_one integer,
field_two integer NOT NULL,
fk_field integer,
field_date datetime,
fk_user_mod integer NOT NULL, -- Last updater, foreign key of llx_user
import_key varchar(14) -- Use by import process
)type=innodb;
Table and fields structures
- Structure of tables.
- rowid INTEGER AUTO_INCREMENT PRIMARY KEY that is technical id of record - entity INTEGER default 1 that is id for the multicompany feature - date_creation datetime that is the creation date - tms timestamp that will contain date of last modification (the database manages this field automatically, no need to manage it by the code, just create the field) - import_key that will contains the import code YYYYMMDDHHMMSS if you make mass import.
Eventually
- fk_user_creat integer that is the id of user making creation - fk_user_modif integer that is the id of user making change - fk_user_valid integer that is the id of user validating record - fk_soc integer that is the ID of the Third party (if applicable)
Note field:
- note_private text for private comment of the object - note_pubic text for public comment of the object
or
- Type of fields:
- integer for an any of foreign key - double(24,8) for any amount - double(6,3) for any vat rate - real for a quantity - varchar for a string (also if length is 1, the type char is more and more deprecated) - timestamp for a field date+time that is automatically updated - datetime for a field date+time - date for a field date - text or medium text for large fields (no index allowed on such fields)
- All tables has a prefix to avoid name conflicts with other projects. In current version this prefix is fixed ans can't be modified. Its value is llx_. In a future version this value should be modified during installation process.
Primary keys
Foreign keys
Alternative keys
Index performance
SQL Coding rules
- Alias usage/Fields naming
- Using SELECT * is forbidden ! When using SELECT you must define complete list of fields to get. This avoids confusion. Example:
- Into SQL requests, you must quote fields except the fields that contain amounts which must be stored as double or real type. Quotes on numbers may result in saving as a different value. For example 412.62 in an insert will be saved as value 412.61999512 into database (due to implicit conversion string to numeric) if the target field has type double(24,8). Only PHP see value 412.61999512. Other tools will see 412.62 giving a sense that there is no problem. But it's PHP that has the good vision. There is really a wrong value into database. By removing quotes on numbers, no problem occurs.
Example:
Good: INSERT INTO table_1 (field_txt, field_num) VALUES ('txt', 412.62)
Bad: INSERT INTO table_1 (field_txt, field_num) VALUES ('txt', '412.62')
Note, problem of float numbers is same problem on all langauges and not only when inserting data into database. It occurs also with any language when you work on "real" numbers, so numbers must be, as soon as they are affected, cleaned with function price2num with second parameter defined to : 'MU' (for unit prices), 'MT' (for total prices) or 'MS' (otherwise) depending on usage of number. (see function documentation)
- Functions NOW, SYSDATE or DATEDIFF are forbidden inside SQL requests. If you must use the current date into a field, value must come from the PHP and not from the database engine. This is for better portability of code and correct management of TimeZone.
For example, don't do:
but do:
but do:
Mysql specificities
- Tables must be declared with format InnoDB.
- Dolibarr MUST work even if Mysql option strict is active.
PostgreSQL specificities
MySQL Syntax:
PgSQL Syntax:
There is no native SQL request "update from" in dolibarr core. But in your module you should do :
} else {
HTML norms
Syntax rules
- HTML used must be HTML compliant and not XHTML. All attributes of HTML tags must be in lower case and quoted with ".
- Links href must be absolute and use the function dol_buildpath() to get absolute path from a relative path and img tag must be build using function img_picto().
For example:
- HTML tables must have columns with no forced width, except for columns that contains data we know the length. For example, a column with a picto only can be forced to with="20px".
- Javascript/ajax code and call to javascript files into php pages must be avoided. However, if you need to include javascript code, you must add a condition on "$conf->use_javascript_ajax"
... // php code generating javascript here
- Popup windows must not be used, except for tooltips (and must have a condition as explained before).
- External scripts must be written in Perl if they can't be written in PHP. Usage of another language is not forbidden but must be argued before in the development mailing-list.
External templating framework ?
All templating frameworks are just preprocessor, BEFORE PHP. It can't be faster than PHP alone. When we say "speed is increased because templating framework use a cache", you must read in fact "the overtime spent by the framework is reduced by cache, not the speed of processing PHP file". We should say "any templating framework has an overload over PHP, the cache of framework, just reduce the slowing effect of having this framework", but not "the speed is increased, it is always decreased compared to pure PHP".
Also, keeping a 100% isolation between code and HTML output is interesting in only 1 situation: When teams building design is complety different than team building logic code, AND if you build not too sophisticated pages, AND with no need of too many Ajax features (this need to know how code works). And this situation is surely not the Dolibarr future (team will often be same, Ajax will be more and more present, event if I hope not too much, and screens are more and more dependent of dynamic or contextual events, difficult to have this with onesimple template without transforming the template into a page with high level of code).
Skeleton code
- 1 that serves as an example of the module description: myModule.class.php
- 1 that serves as an example of code for creating a new class: skeleton_class.class.php
- 1 that serves as an example of code for creating a new page: skeleton_page.php
- 1 that serves as an example of code for creating a script for executing command lines: skeleton_script.php
Dates and Timezones
- A date into memory must always be stored with Timestamp GMT format.
- A date stored into database, is the GMT Timestamp of date submitted into the request usng the PHP server timezone. This does not apply to date update automatically by database (fields tms into database).
- Dates that are updated automatically (field tms into database) contains a GMT Timestamp GMT of date when change is done. The select will also use the db->jdate (that use PHP server TZ) to convert read data into a GMT Timestamp into memory. So if timezone of database differs from timezone of PHP server (one of them is not correctly set), you may experience differences between creation date and update date.
- Manipulation date with PHP must be done using the Dolibarr date functions: dol_now(), dol_mktime(), dol_stringtotime(), dol_getdate(), dol_time_plus_duree(). You may also find other functions available into file date.lib.php.
UTF8/ISO encoding
- In database, data is stored in UTF8 or ISO. It depends on the database's pagecode therefore these options are set at creation time. In any case, Dolibarr's database driver (in lib/database) deals with it to convert from/to UTF8 at insertion and readout.
- Memory data is stored in UTF8 (PHP object instances).
- Screen displayed web pages are UTF8 (for versions prior to 2.5.1, the deprecated $character_set parameter from conf.php file defines output format).
print 239.2 - 229.3 - 9.9;
Creation of tables
Comparing version
if (versioncompare($version,array(5,0,-4)) >= 0) { //mycode for 5.0 only; } // For dolibarr 5.0.* (the -4 means we include also alpha, beta, rc and rcX)
if ((float) DOL_VERSION >= 5.0) { //mycode for 5.0 only; } // For dolibarr 5.0.*
Logs
Working directory
dol_mkdir($mymoduledir);
Patterns of code organization
- The Transaction Script (The source code is linear for each user action).
- The Domain Model
- The Table Module
- The Table And Row Data Gateway
- The Active Record
- The Data Mapper
