Tester documentation
Revision as of 10:21, 27 July 2018 by Udo.tamm (talk | contribs)
This page try to give people who want to test Dolibarr some information required to work correctly.
Tester guideline
Dolibarr team is looking for people ready to test software.
  • Choose which version to test.
We need testers each time a beta version is started. You will find last beta version int the Beta and pre-release version section of the download page http://www.dolibarr.org/downloads/
  • Install the version.
    • If you are not a technical user, we recommand to install DoliWamp distribution (Dolibarr installer for Windows).
    • If you are a technical user, we recommand to install Dolibarr standard distribution with an old version of PHP (5.2 for example) and with Postgresql (postgresl is more strict than mysql so better to find bugs).
  • Once Dolibarr is installed, just make tests and report bugs onto the Bug tracker: !! this website is offline !! https://doliforge.org/tracker/?group_id=144&atid=246
Other pages related to test process
