Module Hosting
Hosting | |
Numéro/ID du module | 1600 |
Doc développeur du module | Module Hosting (developer) |
Module name | |
Editor / Editeur | Librethic (librethic.io) - Project page on Librethic forge |
Download or buy page / Page achat ou téléchargement | External module - https://www.dolistore.com/en/modules/921-Module-Hosting-V2.html |
Prerequisites / Prérequis |
Last update date / Date mise à jour fiche / Fecha última actualización | 2018-07-12 |
Note / Nota |
Manage internet hosts and extensions with Dolibarr.
You can add a host by clicking the button labeled "Hosting" in the main menu. A link is then present in the left menu to access the form to create the host object.
Extensions
In the module hosting alone, a host does not have a lot of properties. To overcome an extension system is available to manage other types of information such as the domain name or IP address and re-use these data to perform treatments.
For the time extension is available to manage (administratively) of Internet domain names in Dolibarr. More info at Dolistore website
More info
Acquire the module: www.dolistore.com
