Module Exports En
Exports
Numero/ID of module 240
To export Dolibarr data, there is several solutions described here. This page describe solution using the export module. Solutions to make mass imports are described in the page Mass imports.
  1. Go to Menu-> Tools -> New Export and choose a predefined dataset.
  2. Choose a predefined (by you) export profile or manually choose the fields you want to include in the export file.
  3. Next, add any filters you may wish to place on the values of those fields.
  4. Next, change the position/column of the fields in the export file. You may save the selections you have made as an export profile/template for future use.
  5. Next, choose a format for the export file from the dropdown list and click on Generate.
  6. After few seconds, a link to the file is shown for download.
Possible formats are CSV / TSV (Text files) or XLS 2007 / 95 (native Excel files).
Outils.png Develop your own export script
If there is no predefined dataset that match your need and have program knowledge, you can also develop your own script. Any language can be used if this language can read a database. You just have to read the table of the entity you want to export and build a file, with format of your choice, from any fields available in table. So the only thing to know is which table contains data you want to export. To help you, the page Table SQL presents you the list of all Dolibarr tables.
Note that versions after 2.6 allow "admin" users to see the SQL code used to build export requests when using the module.
