Module Woocommerce EN
Overview
Module name Woocommerce
Editor / Editeur Open-DSI continues the work of Teclib
Dolibarr min version: 4.0.0+ Woocomerce version 3.x+    Dolibarr max version: {{{maxversion}}}
Last update date / Date mise à jour fiche / Fecha última actualización 2017-11-11
Feature/Plugin
The Woocommerce module has to be installed on your Dolibarr instance (rep. htdocs/custom) to work properly. To access Woocommerce, Dolibarr uses by default
the Woocommerce's WebServices (REST API v2).
Woocommerce
To be defined
Dolibarr module
From the application
Manually
unzip modulefile.zip
Setup on Woocomerce side
To be defined
Setup on Dolibarr side
Setup > Other setup:
ECOMMERCENG_DISABLE_LOG_IN_NOTE => 1 (Disable the log in the private note)
ECOMMERCENG_DISABLE_MAGENTO_PRICE_TYPE => 1 (Disable the price type managment for magento)
ECOMMERCENG_BILLING_CONTACT_NAME => 'Choose your Billing contact/address name' (Set name for the billing contact/address)
ECOMMERCENG_SHIPPING_CONTACT_NAME => 'Choose your Shipping contact/address name' (Set name for shipping contact/address)
ECOMMERCENG_SHOW_DEBUG_TOOLS => 0 (Show init/purge/debug tools into site page)
ECOMMERCENG_DISABLED_ERROR_FOR_SOCIETE_ID_0 => 1 (Disable error for the creation of an order when societe id = 0 (Administrator, anonymous, ...))
To be defined
Syncronize Woocommerce with Dolibarr
Actions in Woocommerce Adjustments in Dolibarr When Note
Categories established/modified in Woocommerce They are changing in Dolibarr into sub-categories of the parent category, used for Mageto categories (defined in the module setup) It requires the user to click on "Woocommerce to Dolibarr sync" button
NA
Table llx_ecommerce_category is updated to remember the link between dolibarr categorie id and remote Woocommerce id.
Due to the fact that there is no option to search the last categories, modified over time, this sync might be slow down by the high number of categories
Products created/modified products/stock in Woocommerce They are set up in Dolibarr (and linked to its categories NA).
If the module supply is enabled and Supply synchronisation direction was set to "ecommerce2dolibarr", it will be initialised/updated in the warehouse (defined in the eCommerce dolibarr module setup)
Available
Table llx_ecommerce_product is updated to remember the link between dolibarr product id and remote Woocommerce id
Informations concerned:
  - Product : Product type (Product or Service(=Virtual in Woocommerce)), Ref (UGS in Woocommerce, Activated 'Elephant' code generator in module preferences if UGS is probably empty), Label (Name in Woocommerce), Description, Weigth (Kg), Price, envente (Purchasable in Woocommerce), Product finished type (Fixed at Manufactured), Min price (Price in Woocommerce), Url (Permalink in Woocommerce), Stock quantity
  - Product Variation : Product type (Product or Service(=Virtual in Woocommerce)), Ref (UGS in Woocommerce, Activated 'Elephant' code generator in module preferences if UGS is maybe empty), Label (Name & liste (attribute name: attribute option) in Woocommerce), Description, Weigth (Kg), Price, envente (Purchasable in Woocommerce), Product finished type (Fixed at Manufactured), Min price (Price in Woocommerce), Url (Permalink in Woocommerce), Stock quantity
Thirdparties and contacts/addresses created/modified into Woocommerce They are also created in Dolibarr It requires the user to click on "Woocommerce to Dolibarr sync" button
Available
Table llx_ecommerce_societe and llx_ecommerce_socpeople is updated to remember the link between dolibarr thirdparty id and remote Woocommerce id. To determine if a thirdparty already exists, Woocommerce checks the ref. To determine if a contact already exists, Woocommerce checks all fields: firstname, last name, address, zip, town (and thirdparty).
  - Thirdparties : Name (First name & Last Name), Email, Type client (Fixed at Client/Prospect)
  - Contact/addresses - Billing: Type (Fixed at Invoice), Name and last name ('Billing' by default or ECOMMERCENG_BILLING_CONTACT_NAME), Email, Address (Address 1 & Address 2), City, Postcode, Country, Phone
  - Contact/addresses - Shipping (If they are not set up, it could be done from the billing address): Type (Fixed at Delivery), Name and last name ('Shipping' by default or ECOMMERCENG_SHIPPING_CONTACT_NAME), Address (Address 1 & Address 2), City, ZIP, Country
Orders created/modified in Woocommerce They are also created in Dolibarr It requires the user to click on "Woocommerce to Dolibarr sync" button
Available
Table llx_ecommerce_order is updated to remember the link of dolibarr order id and remote Woocommerce id
   The orders created by another person than Customer user (Administrator, Anonymous, ...) are not created/modified
  - Order: Ref client (Id order in Woocommerce),Purchase order date (Created date in Woocommerce), Delivery date (Completed date in Woocommerce), Status (pending => Validated, on-hold & processing => Accepted, cancelled & Failed => Cancelled, Completed & Refunded => Closed), Payment status (pending & processing & on-hold & cancelled & Failed => Not paid, Completed & Refunded => Paid), Private note (Customer's notes in Woocommerce)
  - Product: Description (Name in Woocommerce), Product type (Fixed at Simple), Price, Quantity, VAT rate (Calculated with total and total tax closed to VAT rate in Dolibarr)
  - Shipping line of the product (Displayed by default or ECOMMERCENG_SHIPPING_NOT_DISPLAY_IF_NULL): Description ('Shipping - ' & Shipping method title in Woocommerce if present), Price (Total shipping in Woocommerce), VAT rate (Calculated with shipping total and shipping tax closed to VAT rate in Dolibarr)
  - Order address: Billing Contact/addresses in Thirdparties
  - Invoice address: Billing Contact/addresses in Thirdparties
  - Shipping address: Shipping Contact/addresses in Thirdparties
Shipment created/modified in Woocommerce By creating a shipment in Woocommerce the statut of the order is changing from "pending" to "processing". Considering the modified status of the order, see the cas above "Order created/modified in Woocommerce". It requires the user to click on "Woocommerce to Dolibarr sync" button
NA
Note: The shipment is not downloaded onto Dolibarr, only the status of Dolibarr Order is changing according to the Woocommerce order.
Note: You may choose to manage shipment in Dolibarr or in Woocommerce (we recommand to create/update the shipments on Dolibarr rather than on Woocommerce).
Invoices created/modified in Woocommerce They are also created in Dolibarr (with correct status but without payments) It requires the user to click on "Woocommerce to Dolibarr sync" button
NA
Table llx_ecommerce_the bill is updated to host a link between dolibarr invoice id and remote Woocommerce id.
Note: The payment must still be registered manually on Dolibarr.
TODO In a future version of the module,the "Woocommerce to Dolibarr sync" button could be replaced with a scheduled job/script to launch it automaticaly every hour.
Synchronize Dolibarr with Woocomerce
The synchronization is happening in real time.
Actions in Dolibarr Adjustments in Woocomerce When Note
Categories created into Dolibarr Currently there is no update in Woocomerce. In a future version of the module, it will be possible if the category belongs to the parent category of Woocomerce, defined in the module setup There is no set up /update currently done in Woocomerce. In a updated version, the sync will happen in real time
NA
Categories modified in Dolibarr No update is currently done in Woocomerce. In a future version of the module, Woocomerce will be updated if the category is linked to Woocomerce (category was setted up by a "Woocomerce to Dolibarr sync") There is no set up /update currently done in Woocomerce. In a future version of the module, the sync will happen in real time
NA
Products created in Dolibarr None. In a future version of the module, the the products will be set up in Woocomerce if the category belongs to the the nested categories of Woocommerce No prodoctut category is set up in Woocomerce. In a future version of the module, the sync will happen in real time
TODO
Products or Stock modified in Dolibarr The update in Woocommerce is done if the product is linked to Woocommerce (product was created by a "Woocommerce to Dolibarr sync")
If the module stock is enabled and Stock synchronisation direction was set up to "dolibarr2ecommerce", then the stock is also overwritten on Woocommerce
In real time
Available
  - Product (PRODUCT_MODIFY event): Name (Label in Dolibarr), Status (published (for sale) or pending), Description, UGS (Ref in Dolibarr), Regular price (Price in Dolibarr), Weigth (Kg)
  - Product Variation (PRODUCT_MODIFY event): Description, UGS (Ref in Dolibarr), Regular price (Price in Dolibarr), Weigth (Kg)
  - Stock (STOCK_MOVEMENT event): Stock quantity, In stock
Thirdparties created None. In a future version of the module, this will be created in Woocommerce if it belongs to the category of Woocommerce thirdparties (defined in setup) There is no set up currently done in Woocommerce. In a future version of the module, the sync will happen in real time
NA
Thirdparties modified into Dolibarr The update in Woocommerce is done if the thirdparty belonged to Woocommerce (thirdparty was set up by a "Woocommerce to Dolibarr sync") In real time
Available
  - Thirdparties (COMPANY_MODIFY event): Email
Contacts/addresses created in Dolibarr None. In a future version od the module, they will be created in Woocommerce if the thirdparty was set up as a category of Woocommerce thirdparties (defined into setup) There is no set up currently done in Woocommerce. In a future version of the module, the sync will happen in real time
NA
Contacts/addresses modified in Dolibarr The update into Woocommerce is done if the contact/address is linked to Woocommerce (contact/address was created by a "Woocommerce to Dolibarr sync") In real time
Available
  - Contacts/addresses Billing (CONTACT_MODIFY event): Address 1 (First address row in Dolibarr), Address 2 (Next address row in Dolibarr), City (Town in Dolibarr), Postcode (Zip in Dolibarr), Country, Phone (Phone pro in Dolibarr)
  - Contact/addresses Shipping (CONTACT_MODIFY event): Address 1 (First address row in Dolibarr), Address 2 (Next address row in Dolibarr), City (Town in Dolibarr), Postcode (Zip in Dolibarr), Country
Orders created (validated) in Dolibarr None Orders are created directly in the backoffice, it's not necessary to appear in the ecommerce. See next cas below.
Orders modified in Dolibarr The Order will be updated in Woocommerce if it is linked to Woocommerce (the order was created by a "Woocommerce to Dolibarr sync") In real time
Available
  - Order (ORDER_MODIFY & ORDER_CLOSE & ORDER_CLASSIFY_BILLED events): Status (cancelled => cancelled, validated => pending, accepted & shipment on process => processing, closed => completed)
Shipments created (validated) in Dolibarr Shipment will be created/modified in Woocommerce if the source order of shipment was created by a "Woocommerce to Dolibarr sync" In real time
NA
Shipments modified (closed) in Dolibarr The task is unavailable because there is no procedure in Magento.
NA
Invoices created (validated) in Dolibarr None. In a future version of the module, the invoice will be created/modified in Woocommerce if the source order is rooted in Woocommerce There is no set up /update currently done in Woocommerce. In a future version of the module, the sync will be happen in real time
TODO
Invoices modified in Dolibarr (When the status of the bill updates into "paid", due to the payment) None. In a future version of the module, the invoice will be created/modified into Woocommerce if the source order is rooted in Woocommerce There is no set up /update currently done in Woocommerce. In a future version of the module, the sync will happen in real time
NA
Stock of products modified in Dolibarr (for any reason: the shipment is processed, the order or invoice is validated, depending on the settings that were done in Dollibar in regards to change in the stock. The stock or inventory could be changed also manually) Stock is updated on Woocommerce if the product exists also in Woocommerce In real time
Available
The development of this module is not included into the standard GIT repository of Dolibarr; but inside a dedicated repository, managed by Open-DSI.
TroubleShooting
To be defined...
