Module Scanner
Module name | Select Bank |
Prerequisites / Prérequis |
Last update date / Date mise à jour fiche / Fecha última actualización | 2017-10-30 |
Note / Nota |
Feature
Add menu entry to pilot a scanner plugged to a Dolibarr server
Prérequis
- Dolibarr 3.6.0
- Linux server only
Just go on page to use the scanner and click on Scan button. You will get an image file ready to be downloaded once the scan is finished.
Developpement
