Module Scanner
Revision as of 16:26, 30 October 2017 by Eldy (talk | contribs) (Created page with "Category:Complementary modules Category:Scanner Category:NLTechno {{TemplateDocDev}} {{TemplateDocUtil}} = Informations = {{TemplateModuleInfo |modulename=Select Bank...")
Module name Select Bank
Last update date / Date mise à jour fiche / Fecha última actualización 2017-10-30
Feature
Add menu entry to pilot a scanner plugged to a Dolibarr server
Prérequis
  • Dolibarr 3.6.0
  • Linux server only
Just go on page to use the scanner and click on Scan
Developpement
