Extrafields
Revision as of 22:57, 18 September 2017 by Eldy (talk | contribs) (→‎Extrafields)
Extrafields
Extrafields allow to add others datas to Dolibarr standard database schema. Introduced in version 3.2, extrafields are now implemented in most business objects :
  • Thirdparties & contacts
  • Users
  • Events
  • Proposal
  • Customer Invoices
  • Orders
  • Supplier Proposal
  • Supplier Invoices
  • Supplier Orders
  • Products & services
  • Member & member type
  • Projects & project tasks (since 3.4)
  • Categories
  • Expense Report
Technical implementation
Each object has its table in database to store values of extrafields.
Datatables extrafield tables models
 llx_BaseTableNAme_extrafields
 rowid                     integer AUTO_INCREMENT PRIMARY KEY,
 tms                       timestamp,
 fk_object                 integer NOT NULL,
 import_key                varchar(14)
An example of mysql definition file for extrafields implementation on an object :
 create table llx_place_room_extrafields
   tms                       timestamp,
   import_key                varchar(14)                          		-- import key
 ) ENGINE=innodb;
Load class for extrafields
To use extrafields all pages need include
require_once DOL_DOCUMENT_ROOT.'/core/class/extrafields.class.php';
Load extrafield array in object
$extrafields = new ExtraFields($db);
$extralabels=$extrafields->fetch_name_optionals_label($object->table_element);
$extralabels will be an array with code and label of extrafields. This code must be placed into the class for example into the function "write_file".
Load extrafield into object
Extrafields are loaded in $object->array_options array.
$object->fetch($rowid);
$object->fetch_optionals($rowid,$extralabels);
This code must be placed just after the above.
Display extrafield value into PDF or HTML
After load extrafields
HTML Exemple
print $object->array_options ['options_XXX'];
Where XXX is the code of the extrafields
PDF example
$pdf->MultiCell (0,5, $outputlangs->convToOutputCharset($object->array_options ['options_XXX']),0,'L'); )
Display extrafield value of lines into PDF or HTML
HTML Exemple
print $object->lines[$i]->array_options['options_XXX'];
PDF example
$pdf->MultiCell (0,5, $outputlangs->convToOutputCharset($object->lines[$i]->array_options['options_XXX']),0,'L');
Before call $object->create() or $object->update()
Values of extrafields sent by form need to be retrieve. For doing that, use this method :
$ret = $extrafields->setOptionalsFromPost($extralabels,$object);
Inside edit page to display extrafields
$reshook=$hookmanager->executeHooks('formObjectOptions',$parameters,$object,$action);    // Note that $action and $object may have been modified by hook
if (empty($reshook) && ! empty($extrafields->attribute_label))
      print $object->showOptionals($extrafields,'edit');
Inside view page to display extrafields
      print $object->showOptionals($extrafields);
After fetch method of this object class
require_once(DOL_DOCUMENT_ROOT.'/core/class/extrafields.class.php');
$extrafields=new ExtraFields($this->db);
$extralabels=$extrafields->fetch_name_optionals_label($this->table_element,true);
if (count($extralabels)>0) {
	$this->fetch_optionals($this->id,$extralabels);
After Update method of this object class :
// Actions on extra fields (by external module or standard code)
// FIXME le hook fait double emploi avec le trigger !!
$hookmanager->initHooks(array('HookModuleNamedao'));
$parameters=array('socid'=>$this->id);
$reshook=$hookmanager->executeHooks('insertExtraFields',$parameters,$this,$action);    // Note that $action and $object may have been modified by some hooks
if (empty($reshook))
	if (empty($conf->global->MAIN_EXTRAFIELDS_DISABLED)) // For avoid conflicts if trigger used
            $result=$this->insertExtraFields();
            if ($result < 0)
            	$error++;
else if ($reshook < 0) $error++;
After delete method of this object class
// Removed extrafields
if (! $error)
      $result=$this->deleteExtraFields();
      if ($result < 0)
        $error++;
        dol_syslog(get_class($this)."::delete erreur ".$errorflag." ".$this->error, LOG_ERR);
Admin pages
$elementtype='facture'; //Must be the $table_element of the class that manage extrafield
Repair Database
Search and find definition of $listofmodulesextra add the new extrafield declaration
$listofmodulesextra=array('societe'=>'societe','adherent'=>'adherent','product'=>'product',
			'socpeople'=>'socpeople', 'commande'=>'commande', 'facture'=>'facture',
			'commande_fournisseur'=>'commande_fournisseur', 'actioncomm'=>'actioncomm',
			'adherent_type'=>'adherent_type','user'=>'user','projet'=>'projet', 'projet_task'=>'projet_task');
How to change the labels of the columns when using models (propals, etc.)
In the PHP code of the model you can change the labels of your extrafield by changing into the function named "_tableau(...)"
