Module NumberWords
Module name | Number to Words |
Prerequisites / Prérequis |
Last update date / Date mise à jour fiche / Fecha última actualización | 2017-09-13 |
Note / Nota |
With this module, Dolibarr is able to translate decimal number or amount into full text strings ("110 dollars" will give "one hundred and ten dollars")
Then see "Usage"
If you are an end user
you can add following key
- __AMOUNT_TEXT__
- __AMOUNT_EXCL_TAX_TEXT__
- __AMOUNT_VAT_TEXT__
- __AMOUNT_MULTICURRENCY_TEXT__
- __AMOUNT_MULTICURRENCY_EXCL_TAX_TEXT__
- __AMOUNT_MULTICURRENCY_VAT_TEXT__
in any "free text for PDF" area in setup of invoices, orders, proposals... This string will be replaced with the amount with tax, without tax or for vat in full clear alphabetic text.
If you use ODT templates, the key to use inside your ODT file are
- {__AMOUNT_TEXT__}
- {__AMOUNT_EXCL_TAX_TEXT__}
- {__AMOUNT_VAT_TEXT__}
- {__AMOUNT_MULTICURRENCY_TEXT__}
- {__AMOUNT_MULTICURRENCY_EXCL_TAX_TEXT__}
- {__AMOUNT_MULTICURRENCY_VAT_TEXT__}
If you are a developer
You can also use, anywhere in the code, the method
$langs->getLabelFromNumber($mynumber,0|1)
to get full text string of a number (if second parameter is 0) or an amount (if second parameter is 1).
