Application Android - Mobilid EN
Module name | PHPSysInfo |
Editor / Editeur | Z-Application - www.mobilid.eu |
Download or buy page / Page achat ou téléchargement | External module - www.dolistore.com - Google Play |
Prerequisites / Prérequis |
Last update date / Date mise à jour fiche / Fecha última actualización | 2017-09-9 |
Note / Nota |
Mobilid can do Stock inventory, Customer order collecting, Supplier order dispatching Order creating and Prospect contacting. Mobilid has build in barcode scanning and can connect to bluetooth barcode scanners. Add product photo to Dolibarr using device camera. Build in Mobile Device Managment.
When installed in custom folder you will have to add /custom to the connection URL in the Mobilid app.
You can read the full documentation at https://docs.z-application.com
