Module Timesheet
<keywords content="timesheet, Dolibarr, interface, project, task, report, approval" />
Module name | timesheet |
Editor / Editeur | delcroip |
Prerequisites / Prérequis | projects
Last update date / Date mise à jour fiche / Fecha última actualización | 2017-08-14 |
Note / Nota | Latest Module version: 1.5.1 |
Manual
Timesheet 1.5 manual Timesheet 2.0.1 manual
- Timesheet interface for all the user task per week - Generate report on user and on project per month - whitelist to show only some project/task (if no whitelist define all task are showed) - Approval of the timesheets per the N+1
Change logs
2.0.1 Change log from 2.0
* Project approval corrected (for non admin no approval was shown) * PHP warning removed * Home timesheet box correted (was not showing the # of timesheet to approve)
2.0 Change log from 1.5.1
* Week on two month are spliced to enable monthly approval * Chained approval for team & project. * Create invoice with ad-hoc and already defined service based on time saved. * Report always shows time in day and hours * Layout change for the setup page * Layout change for the favorite handling * Email are sent to user when a timesheet is rejected by the team leader * Note on task are shown as info when hoovering over the task line * Searchbox are available instead of dropdown list (use other core module setup). * More translation (ES, DE, IT, FR, US , mostly automated) * Note editing available for each tasks (also in the approval flow)
Change log from 1.5
* Support dolibarr 4.0.1 * Hidden option to join file to timesheets via the setting TIMESHEET_ADD_DOCS
Change log from 1.4.3:
* Timesheet approval by N+1, * Reminder (email) for to be approved timesheet possible through dolibarr planned tasks * admin wiew for the Approval (change a approval status outside the normal approval flow) * Home box with the pending timesheet to be approved * Blocking some weekdays (e.g week ends) * Holiday showed in the timesheet * Holiday time can be included in the timesheet totals * Typo correction for French. * Posibility to add a note * Compatible with dolibarr 3.9.2
Change log from 1.4.1:
* Correction of the Spanish language (thanks to vinclar) * Possible to deactivate the dolibarr Ajax for the dropdown list for the setup page (in case of issue to add whitelist) * Keep the whitlistmode after submit / go to date / next / previsous week
Change log from 1.4:
* Bugfix for the tasktime date in the project page * Link to have the different whitelist behaviour (black list, and none) * Spanish language (google trad) * Typo correction for French * Support the print mode for timesheet & the report * Show the project open to everyone on the new whitelist page
Change log from 1.3.7:
* layout improvement: timesheet, setup page, reports * whitelist to show only some project/task * taslk column customisation * new task column: company, parent task * new report option: report all, export friendly layout * user report available for the N-2, N-3
Change log from 1.3.6:
* compatible avec dolibarr 3.7 * Change log from 1.3.3: * Works with PHP<=5.3 * Possibility to remove the 0:00 * Color code for already filled tasktime / new tasktime and error * Bux fixes in the report * Better date dialog * N+1 is able to check the user report of his N's
