Module Woocommerce EN
Overview
Module name | Woocommerce |
Editor / Editeur | Open-DSI continues the work of Teclib |
Prerequisites / Prérequis |
Dolibarr min version: 4.0.0+ Woocomerce version 3.x+ Dolibarr max version: {{{maxversion}}} |
Last update date / Date mise à jour fiche / Fecha última actualización | 2017-07-27 |
Note / Nota |
Feature/Plugin
The Woocommerce module must be installed on your Dolibarr instance (htdocs/custom) to work properly. To access Woocommerce Dolibarr is using using default Woocommerce's WebServices (REST API v2). Warning: The module in still in developpement stage and it uses the same core as Module ECommerce NG (Magento) EN.
Woocommerce
To be defined
Dolibarr module
From the application
Manually
unzip modulefile.zip
Setup on Woocomerce side
To be defined
Setup on Dolibarr side
Setup > Other setup:
ECOMMERCENG_DISABLE_LOG_IN_NOTE => 1 (Disable the log in the private note)
ECOMMERCENG_DISABLE_MAGENTO_PRICE_TYPE => 1 (Disable the price type managment for magento)
ECOMMERCENG_BILLING_CONTACT_NAME => 'Choose your Billing contact/address name' (Set name for the billing contact/address)
ECOMMERCENG_SHIPPING_CONTACT_NAME => 'Choose your Shipping contact/address name' (Set name for shipping contact/address)
ECOMMERCENG_SHOW_DEBUG_TOOLS => 0 (Show init/purge/debug tools into site page)
ECOMMERCENG_DISABLED_ERROR_FOR_SOCIETE_ID_0 => 1 (Disable error for the creation of an order when societe id = 0 (Administrator, anonymous, ...))
To be defined
Synchronize from Woocommerce to Dolibarr
Activites in Woocommerce | Effects in Dolibarr | When | Note |
Create/modifie categories in Woocommerce | Created into Dolibarr as sub-categories of the parent category used for Mangeto categories (defined into module setup) | Manual click on "Woocommerce to Dolibarr sync" button | NA Table llx_ecommerce_category is updated to store a link between dolibarr category id and remote Woocommerce id. Due to a lack of search on last modified time on Woocommerce API, this sync may be slow if you have a high number of categories
Products or Stock created/modified into Woocommerce | Created into Dolibarr (and linked to its categories NA). If module stock is enabled and Stock synchronisation direction was set to "ecommerce2dolibarr", stock is also initialised/updated into warehouse defined into eCommerce dolibarr module setup |
Manual click on "Woocommerce to Dolibarr sync" button | Available Table llx_ecommerce_product is updated to store a link between dolibarr product id and remote Woocommerce idInformations concerned: - Product : Product type (Product or Service(=Virtual in Woocommerce)), Ref (UGS in Woocommerce, Activated 'Elephant' code generator in module preferences if UGS is maybe empty), Label (Name in Woocommerce), Description, Weigth (Kg), Price, envente (Purchasable in Woocommerce), Product finished type (Fixed at Manufactured), Min price (Price in Woocommerce), Url (Permalink in Woocommerce), Stock quantity - Product Variation : Product type (Product or Service(=Virtual in Woocommerce)), Ref (UGS in Woocommerce, Activated 'Elephant' code generator in module preferences if UGS is maybe empty), Label (Name & liste (attribute name: attribute option) in Woocommerce), Description, Weigth (Kg), Price, envente (Purchasable in Woocommerce), Product finished type (Fixed at Manufactured), Min price (Price in Woocommerce), Url (Permalink in Woocommerce), Stock quantity |
Thirdparties and contact/addresses created/modified into Woocommerce | Created into Dolibarr | Manual click on "Woocommerce to Dolibarr sync" button | Available Table llx_ecommerce_societe and llx_ecommerce_socpeople is updated to store a link between dolibarr thirdparty id and remote Woocommerce id. To know if a thirdparty already exists, Woocommerce check on the ref. To know if a contact already exists, Woocommerce check on all fields firstname, lastname, address, zip, town (and thirdparty).Informations concerned: - Thirdparties : Name (First name & Last Name), Email, Type client (Fixed at Client/Prospect) - Contact/addresses - Billing: Type (Fixed at Invoice), Name and last name ('Billing' by default or ECOMMERCENG_BILLING_CONTACT_NAME), Email, Address (Address 1 & Address 2), City, Postcode, Country, Phone - Contact/addresses - Shipping (If not set, set from billing address): Type (Fixed at Delivery), Name and last name ('Shipping' by default or ECOMMERCENG_SHIPPING_CONTACT_NAME), Address (Address 1 & Address 2), City, Postcode, Country |
Orders created/modified into Woocommerce | Created into Dolibarr | Manual click on "Woocommerce to Dolibarr sync" button | Available Table llx_ecommerce_commande is updated to store link of dolibarr order id and remote Woocommerce idInformations concerned: Order created by Other than Customer user (Administrator, Anonymous, ...) is not created/modified - Order: Ref client (Id order in Woocommerce), Date commande (Created date in Woocommerce), Delivery date (Completed date in Woocommerce), Status (pending => Validated, on-hold & processing => Accepted, cancelled & Failed => Cancelled, Completed & Refunded => Closed), Billed status (pending & processing & on-hold & cancelled & Failed => Not paid, Completed & Refunded => Paid), Private note (Customer note in Woocommerce) - Item: Description (Name in Woocommerce), Product type (Fixed at Simple), Price, Quantity, VAT rate (Calculated with total and total tax closed to VAT rate in Dolibarr) - Shipping line into item (Displayed by default or ECOMMERCENG_SHIPPING_NOT_DISPLAY_IF_NULL): Description ('Shipping - ' & Shipping method title in Woocommerce if present), Price (Total shipping in Woocommerce), VAT rate (Calculated with shipping total and shipping tax closed to VAT rate in Dolibarr) - Order address: Billing Contact/addresses in Thirdparties - Invoice address: Billing Contact/addresses in Thirdparties - Shipping address: Shipping Contact/addresses in Thirdparties |
Shipment created/modified in Woocommerce | Creating a shipment in Woocommerce is changing Woocommerce status of the Order from "pending" to "processing". Because it is changing status of order, see case "Order created/modified into Woocommerce". | Manual click on "Woocommerce to Dolibarr sync" button | NA Note: The shipment is not downloaded into Dolibarr, only status of Dolibarr Order will be changed like is the Woocommerce order.Note: You may choose to manage shipment on Dolibarr or Woocommerce (we recommand to create/update shipments on Dolibarr and not into Woocommerce). |
Invoices created/modified into Woocommerce | Created into Dolibarr (with correct status but without payments) | Manual click on "Woocommerce to Dolibarr sync" button | NA Table llx_ecommerce_facture is updated to store a link between dolibarr invoice id and remote Woocommerce id.Note: Payment must still be recorded manually on Dolibarr. |
TODO In a future version, the "Woocommerce to Dolibarr sync" button could be replaced with a scheduled job/script to launch it automaticaly every hour for example.
Synchronize from Dolibarr to Woocomerce
Action into Dolibarr | Effect into Woocomerce | When | Note |
Categories created into Dolibarr | No update is currently done on Woocomerce. In a future version, creation will be done into Woocomerce if category is inside the parent category for Woocomerce, defined into module setup | No creation/update is currently done on Woocomerce. In a future version, sync will be in real time | NA
Categories modified into Dolibarr | No update is currently done on Woocomerce. In a future version, update will be done into Woocomerce if category is linked to Woocomerce (category was created by a "Woocomerce to Dolibarr sync") | No creation/update is currently done on Woocomerce. In a future version, sync will be in real time | NA
Products created into Dolibarr | None. In a future, creation will be done into Woocomerce if product has a category inside tree of Woocomerce categories | No creation is currently done on Woocomerce. In a future version, sync will be in real time | TODO
Products or Stock modified into Dolibarr | Update into Woocommerce is done if product is linked to Woocommerce (product was created by a "Woocommerce to Dolibarr sync") If module stock is enabled and Stock synchronisation direction was set to "dolibarr2ecommerce", then stock is also overwritten on Woocommerce |
Real time | Available Informations concerned: - Product (PRODUCT_MODIFY event): Name (Label in Dolibarr), Status (publish (en vente) or pending), Description, UGS (Ref in Dolibarr), Regular price (Price in Dolibarr), Weigth (Kg) - Product Variation (PRODUCT_MODIFY event): Description, UGS (Ref in Dolibarr), Regular price (Price in Dolibarr), Weigth (Kg) - Stock (STOCK_MOVEMENT event): Stock quantity, In stock |
Thirdparties created | None. In a future version, creation will be done into Woocommerce if thirdparty has the category of Woocommerce thirdparties (defined into setup) | No creation is currently done on MaWoocommerceento. In a future version, sync will be in real time | NA
Thirdparties modified into Dolibarr | Update into Woocommerce is done if thirdparty is linked to Woocommerce (thirdparty was created by a "Woocommerce to Dolibarr sync") | Real time | Available Informations concerned: - Thirdparties (COMPANY_MODIFY event): Email |
Contact/addresses created into Dolibarr | None. In a future version, creation will be done into Woocommerce if thirdparty has the category of Woocommerce thirdparties (defined into setup) | No creation is currently done on Woocommerce. In a future version, sync will be in real time | NA
Contact/addresses modified into Dolibarr | Update into Woocommerce is done if contact/address is linked to Woocommerce (contact/address was created by a "Woocommerce to Dolibarr sync") | Real time | Available Informations concerned: - Contact/addresses Billing (CONTACT_MODIFY event): Address 1 (First address line in Dolibarr), Address 2 (Next address lines in Dolibarr), City (Town in Dolibarr), Postcode (Zip in Dolibarr), Country, Phone (Phone pro in Dolibarr) - Contact/addresses Shipping (CONTACT_MODIFY event): Address 1 (First address line in Dolibarr), Address 2 (Next address lines in Dolibarr), City (Town in Dolibarr), Postcode (Zip in Dolibarr), Country |
Orders created (validated) into Dolibarr | None | Orders created directly into backoffice does not need to appear into ecommerce. See next line for Orders modified. | |
Orders modified into Dolibarr | Order will be updated into Woocommerce if order is linked to Woocommerce (order was created by a "Woocommerce to Dolibarr sync") | Real time | Available Informations concerned: - Order (ORDER_MODIFY & ORDER_CLOSE & ORDER_CLASSIFY_BILLED events): Status (cancelled => cancelled, validated => pending, accepted & shipment on process => processing, closed => completed) |
Shipments created (validated) into Dolibarr | Shipment will be created/modified into Woocommerce if source order of shipment was created by a "Woocommerce to Dolibarr sync" | Real time | NA
Shipments modified (closed) into Dolibarr | This step does not exists on Mangento, so nothing is done | NA
Invoice created (validated) into Dolibarr | None. In a future, invoice will be created/modified into Woocommerce if source order was coming from Woocommerce | No creation/update is currently done on Woocommerce. In a future version, sync will be in real time | TODO
Invoice modified into Dolibarr (for exemple when status change to paid because of a payment entered) | None. In a future, invoice will be created/modified into Woocommerce if source order was coming from Woocommerce | No creation/update is currently done on Woocommerce. In a future version, sync will be in real time | NA
Stock of a product modified into Dolibarr (whatever is reason: shipment processed, order or invoice validated, depending on your Dolibarr setup of the stock change rule, manuel change of stock or inventory) | Stock is updated on Woocommerce if product exists also in Woocommerce | Real time | Available Informations concerned: - Stock (STOCK_MOVEMENT event): Stock quantity, In stock |
Development of this module is not included into standard GIT repository of Dolibarr but inside a dedicated repository managed by Open-DSI.
- GIT Repository: https://github.com/OPEN-DSI/ecommerceng
TroubleShooting
</lang>
