Module Timesheet
<keywords content="timesheet, Dolibarr, interface, project, task, report, approval" />
Module name timesheet
Editor / Editeur delcroip
Prerequisites / Prérequis projects
Last update date / Date mise à jour fiche / Fecha última actualización 2017-03-8
Note / Nota Latest Module version: 1.5.1
- Timesheet interface for all the user task per week
- Generate report on user and on project per month
- whitelist to show only some project/task (if no whitelist define all task are showed)
- Approval of the timesheets per the N+1
Change logs
Change log from 1.5
* Support dolibarr 4.0.1
* Hidden option to join file to timesheets via the setting TIMESHEET_ADD_DOCS
Change log from 1.4.3:
* Timesheet approval by N+1,
* Reminder (email) for to be approved timesheet possible through dolibarr planned tasks
* admin wiew for the Approval (change a approval status outside the normal approval flow)
* Home box with the pending timesheet to be approved
* Blocking some weekdays (e.g week ends)
* Holiday showed in the timesheet
* Holiday time can be included in the timesheet totals
* Typo correction for French.
* Posibility to add a note
* Compatible with dolibarr 3.9.2
Change log from 1.4.1:
* Correction of the Spanish language (thanks to vinclar)
* Possible to deactivate the dolibarr Ajax for the dropdown list for the setup page (in case of issue to add whitelist)
* Keep the whitlistmode after submit / go to date / next / previsous week
Change log from 1.4:
* Bugfix for the tasktime date in the project page
* Link to have the different whitelist behaviour (black list, and none)
* Spanish language (google trad)
* Support the print mode for timesheet & the report
* Show the project open to everyone on the new whitelist page
Change log from 1.3.7:
* layout improvement: timesheet, setup page, reports
* whitelist to show only some project/task
* taslk column customisation
* new task column: company, parent task
* new report option: report all, export friendly layout
* user report available for the N-2, N-3
Change log from 1.3.6:
* compatible avec dolibarr 3.7
* Change log from 1.3.3:
* Works with PHP<=5.3
* Possibility to remove the 0:00
* Color code for already filled tasktime / new tasktime and error
* Bux fixes in the report
* Better date dialog
* N+1 is able to check the user report of his N's
