Module Projects
Project | |
Numero/ID of module | 400 |
Developer doc. of module | Module Projects (developer) |
What this module does
- Manage project as a hierarchy of tasks.
- Allow to define internal projects (done for your organization).
- Allow to define external projects (done by your organization for a client).
- Allow to allocate internal or external users on tasks.
- Allow to share projects across users, providing to each assigned user the proper view of tasks and projects.
- Allow to track time spend on task per working slot and user.
- Allow to assign any element or document (invoice, order, proposal, intervention, ...) or URL to project and tasks.
- Provide a full view of the project with time planned and spend, Gant view and all documents.
- Support extra fields for projects and task.
- Provide document models for projects and tasks reports.
What this module does not
- Does not support allocating resources other than users on tasks.
Set-up options
Projects > Parameters
Projects > Other Parameters
Dictionaries
Permissions
- Export projects
- to access shared projects and tasks. These are projects and task readable by you (even if you are not assigned to). Depending on your permission, access to this view may be restricted.
Entities and Business rules
Project entity
Properties
Property | Description | Note / Values |
Reference | Generated automatically by a template. It is unique. | See Set-up Options to customize the template. |
Label | The full name of the project. | |
Visibility | This property define the users permissions. |
Status | Current status of the project, updated by the project workflow. |
Start date | Starting date for the project | Could be any valid date in past or future. Note that no control is made between start and end date. |
End date | Ending date for the project | Could be any valid date in past or future. Note that no control is made between start and end date. |
Opportunity status | Value selected from the "Opportunity status for project/lead" dictionary. | Only displayed when "Use projects to follow leads/opportunities" option is set-up. |
Opportunity probability | The percentage associated to the Opportunity status, could be updated manually. | Only displayed when "Use projects to follow leads/opportunities" option is set-up. |
Opportunity amount | Amount of the opportunity in default currency. | Only displayed when "Use projects to follow leads/opportunities" option is set-up. |
Budget | Amount of the budget required for the project in default currency (if any). | |
Description | A text to describe your project. | |
Public Notes | A text area (html) to store public notes on the project. | |
Private Notes | A text area (html) to store private notes on the project. |
Links
Entity linked | Description | Notes |
Users | You could allocate multiple users to a project, specifying a role. Two roles are defined by default, but you could extend it if needed. | There is no limitation to number of users linked, even with the same role. |
Contacts | You could allocate multiple contacts - from different third parties - to a project, specifying a role. Two roles are defined by default, but you could extend it if needed | There is no limitation to number of contacts linked, even with the same role. Contact and User roles could be different if needed. |
Documents | You could upload multiple document files and link them to a project. | Document could also be generated using templates, see Set-up Options to activate the templates. |
URL | You could attach multiple URL links to a project. | |
Commercial proposal | You could attach multiple proposals to a project. | You could create the proposal from the project overview tab. |
Customer order | You could attach multiple customer orders to a project. | You could create the order from the project overview tab. |
Customer invoice | You could attach multiple customer invoices to a project. | You could create the invoice from the project overview tab. |
Customer template invoice | You could attach multiple template customer invoices to a project. | You could create the invoice from the project overview tab. |
Supplier order | You could attach multiple supplier orders to a project. | You could create the order from the project overview tab. |
Supplier invoice | You could attach multiple supplier invoices to a project. | You could create the invoice from the project overview tab. |
Contract | You could attach multiple contracts to a project. | You could create the contract from the project overview tab. |
Expense report | You could attach multiple expense report to a project. | You could create the invoice from the project overview tab. |
Event | You could attach multiple events to a project. | You could create the event from the project overview tab. The Agenda module should be activated. |
Task | You could attach multiple tasks to a project. See below the tasks properties. | The option to manage tasks in a project should be properly activated, see Set-up Options |
Task entity
Properties
Label | The full name of the task. | |
Child of project/task | By default the current project but could be changed to an other project task to create a tasks hierarchy. | |
Assigned to | The user responsible of the task. | By default the task creator. |
Start date | Starting date for the task | Could be any valid date in past or future. Note that no control is made between start and end date neither with project dates. |
End date | Ending date for the task | Could be any valid date in past or future. Note that no control is made between start and end date neither with project dates. |
Planned workload | Planned workload to complete the task in hours and minutes. | |
Declared progress | A percentage to be updated manually. | Could also be updated when capturing time spend on task. |
Description | A text to describe your task. | |
Public Notes | A text area (html) to store public notes on the task. | |
Private Notes | A text area (html) to store private notes on the task. |
Links
Users | You could allocate multiple users to a task, specifying a role. Two roles are defined by default, but you could extend it if needed. | There is no limitation to number of users linked, even with the same role. |
Contacts | You could allocate multiple contacts - from different third parties - to a task, specifying a role. Two roles are defined by default, but you could extend it if needed | There is no limitation to number of contacts linked, even with the same role. Contact and User roles could be different if needed. |
Documents | You could upload multiple document files and link them to a project. | Document could also be generated using ODT templates, see Set-up Options to activate the templates. |
Time spent | You could attach multiple time spent slot to a task. | See the entity attributes below for more details. |
Task | You could attach multiple tasks to a task by using it as a parent task. |
Time spent record
Properties
Links
Workflow
Permissions
See file File:Project.odg that describe different conditions to realize different actions of module.
Create a project
A project can be public or private. Public projects (and all tasks) can be read/edited by anybody with read project permissions. Private project (and all tasks) can be read/edited only by users defined as contact/actors of project + the creator of project (if all contacts are removed, we must keep at least one user authorized on project. This is the creator).
Create a task
- A task can be created on all shared projects or on a project you are a contact for.
- A task is on the root of a project or under another task of the project.
Remove a project
Remove a task
Activity
Activities are time spent to work on tasks.
Examples of use cases
UCMP01: | |
Situation | |
Actions |
