Module Projects
Revision as of 15:27, 4 January 2017 by Bgenere (talk | contribs) (→‎Usage)
Project
Numero/ID of module 400
If you are not familiar with these, read this summary page : Events-Todo-Journal.
What this module does
  • Manage project as a hierarchy of tasks.
  • Allow to define internal projects (done for your organization).
  • Allow to define external projects (done by your organization for a client).
  • Allow to allocate internal or external users on tasks.
  • Allow to share projects across users, providing to each assigned user the proper view of tasks and projects.
  • Allow to track time spend on task per working slot and user.
  • Allow to assign any element or document (invoice, order, proposal, intervention, ...) or URL to project and tasks.
  • Provide a full view of the project with time planned and spend, Gant view and all documents.
  • Support extra fields for projects and task.
  • Provide document models for projects and tasks reports.
What this module does not
  • Does not support automated planning based on user availability.
  • Does not calculate any critical path.
  • Does not support allocating resources other than users on tasks.
Set-up options
Projects > Parameters
Use projects to follow leads/opportunities
If selected you could associate the project to a third party and follow the status of the proposal. This is required to manage external project.
Use projects to follow tasks and time
You need to select this option if you want to enter the detailed tasks of the projects and eventually follow time spend (this is not mandatory even if the option is selected). If not selected the module just allow to follow business opportunities (i.e. sales projects status).
Projects > Other Parameters
Use auto-completion fields to choose project (instead of using a list box)
This could be very useful if you track a large volume of opportunities as projects.
On document of a third-party, can choose a project linked to another third-party
By default only document of the third party attached to the project could be linked to the project, however you may have a sub-contractor that will provide documents related to the project. In this case you need the option activated.
Dictionaries
Permissions
  1. Read projects and tasks (shared project and projects i'm contact for). Can also enter time consumed on assigned tasks (timesheet)
  2. Create/modify projects (shared project and projects i'm contact for)
  3. Delete projects (shared project and projects i'm contact for)
  4. Export projects
  5. Read all projects and tasks (also private projects i am not contact for)
  6. Create/modify all projects and tasks (also private projects i am not contact for)
  7. Delete all projects and tasks (also private projects i am not contact for)
Note that the left menu display two sets of options :
  1. to access your own projects and tasks. These are projects and task you have been assigned to.
  2. to access shared projects and tasks. These are projects and task readable by all users.
Workflow
Permissions
See file File:Project.odg that describe different conditions to realize different actions of module.
Create a project
A project can be public or private. Public projects (and all tasks) can be read/edited by anybody with read project permissions. Private project (and all tasks) can be read/edited only by users defined as contact/actors of project + the creator of project (if all contacts are removed, we must keep at least one user authorized on project. This is the creator).
Create a task
  • A task can be created on all shared projects or on a project you are a contact for.
  • A task is on the root of a project or under another task of the project.
Remove a project
Remove a task
Activity
Activities are time spent to work on tasks.
Examples of use cases
UCMP01:
Situation
Actions
