Module Projects
Project | |
Numero/ID of module | 400 |
Developer doc. of module | Module Projects (developer) |
What this module does
- Manage project as a hierarchy of tasks.
- Allow to define internal projects (done for your organization).
- Allow to define external projects (done by your organization for a client).
- Allow to allocate internal or external users on tasks.
- Allow to share projects across users, providing to each assigned user the proper view of tasks and projects.
- Allow to track time spend on task per working slot and user.
- Allow to assign any element or document (invoice, order, proposal, intervention, ...) or URL to project and tasks.
- Provide a full view of the project with time planned and spend, Gant view and all documents.
- Support extra fields for projects and task.
- Provide document models for projects and tasks reports.
What this module does not
- Does not support allocating resources other than users on tasks.
Set-up options
Projects > Parameters
Projects > Other Parameters
Dictionaries
Permissions
- Export projects
- to access public projects and tasks. These are projects and task readable by all users.
Workflow
Permissions
See file File:Project.odg that describe different conditions to realize different actions of module.
Create a project
A project can be public or private. Public projects (and all tasks) can be read/edited by anybody with read project permissions. Private project (and all tasks) can be read/edited only by users defined as contact/actors of project + the creator of project (if all contacts are removed, we must keep at least one user authorized on project. This is the creator).
Create a task
- A task can be created on all shared projects or on a project you are a contact for.
- A task is on the root of a project or under another task of the project.
Remove a project
Remove a task
Activity
Activities are time spent to work on tasks.
Examples of use cases
UCMP01: | |
Situation | |
Actions |
